Cannot figure out this boost leak/hiss sound
2014 6.7 tuned, dpf delete, egr still intact.
Only under high boost 25-28lbs sounds like a boost leak, it’s definfiely air escaping out of somewhere.
I replaced the coldside intercooler with a metal one instead of plastic....with no change
I also tightened down all the intercooler clamps with no change.
From what I can tell I don’t see any soot around the turbo or up pipes-but from what I remember on my 6.0 when the up pipe was leaking it would hiss all the time.
Anyone know where I should go from here?
are you taking about the boot that connects to the turbo? I didn’t actually pull it off and inspect it, but it did have some slop to it, but didn’t seem to be enough for concern. I’ll glady order one from ford if you think it’s the next place to go.
Looks like you just can’t replace that boot.
This looks like the right one
https://www.oemfordpart.com/oem-part...RpZXNlbA%3D%3D
If you are going to replace the hot pipe you might as well as replace it with one that is cheaper and one that you can get parts for possibly. Here's one from Rudy's on EBay.
https://www.ebay.com/itm/Hot-Side-Intercooler-Pipe-Boot-Kit-For-2011-2016-Ford-6-7L-Powerstroke-Diesel/172315608802?hash=item281ecf86e2:g:RHIAAOSwDZJbEDe H:sc:ShippingMethodStandard!14221!US!-1
Good luck with fixing the leak.
