Issues Draining Diesel Tank
Old Feb 19, 2019 | 10:09 PM
redraider2007's Avatar
redraider2007
I have a 2017 F250 that I am having trouble getting a hose in the tank to drain it. Is there something in the system to not allow a hose in the tank or am I missing something? Thanks!
Old Feb 19, 2019 | 10:16 PM
mhoefer's Avatar
mhoefer
Yes, in the hose, there is a blocker in the fill tube behind the opening that pushes open when you put in the fill nozzle. Take the filler hose off the back of the fill opening and insert your siphon tube down from there if you want to pump it out. It’s to make it harder to steal fuel.
Old Feb 20, 2019 | 11:08 AM
mlsjohn's Avatar
mlsjohn
I drained my 2017 recently thru water separator drain. I put a 5 gal can with short funnel under drain. It took about 15 mins to fill can, just keep your eye on it after a few mins and have another can to slide in place. I took out 20 gals.
Old Feb 20, 2019 | 12:32 PM
2BSDowner's Avatar
2BSDowner
Why are you draining the tank? Are you changing your fuel filter?
Old Feb 20, 2019 | 01:08 PM
mlsjohn's Avatar
mlsjohn
The dealer installed new wiring harness and wanted the tank as near empty as possible for removal.
Old Feb 20, 2019 | 01:23 PM
Mlambert22's Avatar
Mlambert22
Drive it around a bunch, then it sounds like a dealer problem to me
mdacton
Aug 7, 2014 03:18 AM
redman84
Nov 29, 2010 11:05 AM
cowboy73
30
Feb 3, 2008 07:25 PM
adambomb
May 8, 2007 07:44 PM
toproller
May 6, 2006 10:43 AM
