Combining Upgrades / Maintenance Items - Suggestions
Here is some background to consider when offering suggestions... I do not have a significant amount of excess money to burn, however, I would like to give the truck a decent pick-me-up while making some necessary repairs. I'd be open for suggestions for smaller performance upgrades/improvements assuming provided they aren't too costly and they don't require significant continued maintenance.
1.) The driving repair is the glow plugs (only 1 of 8 are working). So... all items necessary to replace the GP's will be performed. I've seen the CCV vent cover o-rings could be performed with this install - are these recommended for what purpose? Question - how many openings/closings can a valve cover gasket withstand? What would I be looking at to determine if they need replacing? Also - I've heard re-torquing the rocker arms is suggested while you're in here.
2.) I've also been leaking some fuel, so I will be rebuilding my fuel bowl (and fuel drain valve) at this same time. I would like a little added pressure to my system, so I've been considering replacing the FPR spring with a slightly higher pressure spring. Thoughts?
3.) I'm going to go ahead and replace my fuel bowl filter - it's not been changed in a while. Anything special I need to consider with this?
4.) Also on the consideration list is the HPOP. I'd like to know what's involved in a rebuild for it - or should I just consider replacing the o-rings and maybe the "non-serviceable" plug on the HPOP (what does this do again?)? I've not been leaking any oil currently, but since I'm going to be tearing things down that far already.
5.) Two additional considerations are the IPR and the ICP sensors. Are these items you normally replace before you have issues or are these best to go ahead and replace while I'm doing everything else?
6.) When I've been reading about all these maintenance items, I've seen people talking about cleaning/replacing the EBP lines - to keep fuel mileage up. I've deleted my EBP valve and I believe my sensor is left unplugged (I'd have to go back and check) - does that mean this would be pointless for me?
Any other suggestions?
My signature is up-to-date, so feel free to ask any comments, and I will be happy to get back to you. Thanks so much in advance.
Knowing they were replaced then, would you still recommend them?
I found a good write-up that I could probably follow, but starting the truck after I've reinstalled them seems more involved (walk-through). Risking "hydro-locking" an engine doesn't sound good at all.
Thanks,
See input below.
I have not replaced glow plugs yet but when I do I plan on replacing the Under Valve Cover Harness and doing a hot retorque of injectors and rocker pedestals.
Yep bowl rebuil is on my list. There is a fuel line “clip” that is notorious for rubbing through the passenger side fuel line. I plan to fix this while I’m in the valley.
Get the top seal o ring on correctly. I plan on pulling the electrical connection to the fuel bowl heater as it’s know to short out and blow fuse 30 and also the pcm (on fuse 30).
I recently replaced my ICP sensor. It wasn’t bad yet but when I pulled the electrical plug it had a small amount of oil pooling in the bottom of the sensor connector. I replaced it with a Motorcraft sensor as the previous owner must have replaced it (new Motorcraft sensor didn’t look anything like the one I replaced)
I replaced my EPB sensor with a new Motorcraft one. Some say the PCM uses this value in some calculations. Some say no big deal either way. ...I didn’t see much difference other than the cold engine EPB number is what it’s supposed to be now.
I’m in the process of putting in as many gages and OBDII monitors as I can stand to look at going down the road so I can see if something is going wrong. Hopefully before major damage.
I have TorquePro app with driver and passenger side EGT gages, fuel pressure and soon to have boost gages in the cab.
Also - I've added the FPR rebuild kit to the list.
replaced too.
Mine ran more quiet when I unplugged it, bought a new one and the engine is now more smooth, not much difference in power just more quite and smooth.
With the EBP tube/sensor just remember that it is still feeding info to the PCM even if its not using it to activate the EBPV...There was a thread a little while back debating the need for the sensor if you've gone full delete to the EBPV but IIRC the consensus was that the EBP sensor still affected fueling characteristics with the PCM
I'll go ahead and grab the CCV o-rings for sure. I can justify $5 o-rings much easier than I can UVCH gaskets.
Update: I just did a bit of research - the harness is different than the gasket - which are usually necessary / recommended? I was seeing about $50 for the harnesses and about $80 for the gasket (per side).
