A/C Oil Question...
Old Feb 17, 2019 | 07:56 PM
ScottyC50's Avatar
ScottyC50
A/C Oil Question...
Good Evening,
I have a 1978 Ford F150 that was converted to an R134A A/C. It needs some oil in the compressor. I am assuming that I DO NOT put in the mineral oil that came with the original truck - now because of the retrofit to R134A I use PAG oil. That is correct? I want to make sure that what I read is correct. As it is still the middle of winter, I will not be doing it soon, but I want to know that I need to get the right stuff. I would also assume that the amount to add is in one of the shop manuals I have (I have all of them). Thanks in advance!
Scott
Old Feb 17, 2019 | 08:17 PM
440 sixpack's Avatar
440 sixpack
I'm not an A/C expert but I have a lot of equipment and we've converted a lot of it. we use ester as a lubricant in converted systems because PAG is not compatible with mineral oil. if you're sure all your mineral oil is gone I suppose you could use PAG.
good luck getting that done.
One thing to know is R134a will not cool as well as your old refrigerant. I don't care what they tell you they're full of crap it never does. it will work, just not as well. on my classics I spend the extra to keep R12 in them.
I'd check with your A/C guy and see what he has to say.
Old Feb 21, 2019 | 03:30 PM
ScottyC50's Avatar
ScottyC50
Thanks so much! I'll check it out!
Old Feb 21, 2019 | 03:39 PM
ford390gashog's Avatar
ford390gashog
Yes use esters oil or clean the system and USE a PAG 46. How do you plan on judging your oil capacity?
daveya48187
1983 - 2012 Ranger & B-Series
May 28, 2013 03:47 PM
F-250 WARHORSE
Jul 8, 2011 08:42 AM
squaredancer
Apr 25, 2008 05:45 PM
Dragrazor
Aug 8, 2004 08:21 PM
jrs_big_ford_f150
Jul 9, 2003 04:35 PM
