Anyone put these wheels on a dentside yet?
Ive been debating on ordering a set. They pretty much look like old school slotted mag wheels, but come in 17" or 18" so I should still be able to buy tires. I have been running 16.5 blade wheels with military tires, but these have got me thinking now...
4wd or 2wd? I say no to faux bead locks on a 2wd but on a 4wd they could look quite good. Check the backspacing they come in though, 4.5" backspace on an 8" wide wheel is usually good on these trucks unless you want tires to stick out more.
The Summit description from the link in the OP says that those have a 5 X 4.5 inch bolt pattern, but if they make them for eight luggers, then they probably make a 5 X 5 as well.
