2003 e350 just clicks
Old Feb 16, 2019 | 04:51 PM
octaneforce's Avatar
octaneforce
Got an issue with my 2003 e350 7.3 van. When you turn the key all i get is a distinct click. I did new batteries and a new starter, and the problem persists. No change, im still just getting a click. What do i do next?
Old Feb 16, 2019 | 05:02 PM
Walleye Hunter's Avatar
Walleye Hunter
Check all of your connections. You have a battery under the frame, too.
Old Feb 16, 2019 | 05:29 PM
octaneforce
everything is new but i guess the existing terminals
could be dirty. Would this clicking condition happen if 1 battery was not making a good connection? Or could the starter spin on only 1 of the batteries
Old Feb 16, 2019 | 05:33 PM
Walleye Hunter
I don't know but I'd make sure they were all clean. I also grease mine.
Old Feb 16, 2019 | 07:13 PM
jimjokjv's Avatar
jimjokjv
I would check all the ground wires too. Since you are certain you have enough power the grounds are most likely the problem. Is the starter in tight and well grounded to the block? Are the negative cable connections to the block clean and secure?
Old Feb 16, 2019 | 08:22 PM
DieselDenny's Avatar
DieselDenny
Clean and spray all grounds and terms as well as the starter. New world.
Denny
Old Feb 16, 2019 | 10:09 PM
'88 E-350's Avatar
'88 E-350
The starter would engage on only one battery. On pickups there's a stud (I think under the air cleaner) where the battery cable is joined to the vehicle power cable, the van probably has a similar junction and might be your culprit. If when you turn it to start other stuff shuts off it's an indication of a bad battery cable/main power feed connection. If everything stays on it's an indication that the problem is within the starter circuit.
Old Feb 17, 2019 | 08:53 AM
bigb56's Avatar
bigb56
Do the 2002-2003 E series have the same connection that the 2002-2003 F series have on the drivers side fender liner where there is a small battery cable attached to 2 fusible links on a post inside a small plastic box? On the F series when this connection goes bad nothing works.
Old Feb 18, 2019 | 10:33 PM
octaneforce
Ended up cleaning the ground from the aux battery to the frame and it worked. The connection was pretty burnt. I smelled something burning the day before this issue started. Thanks for the help!
by the way the lights and stuff stayed on when i turned the key when it was only clicking.
Old Feb 19, 2019 | 08:32 AM
Walleye Hunter
Good you got it, thanks for the update. I always grease those connections when I have them apart to stave off corrosion in the future.
Reef Tech
Jan 31, 2015 07:01 AM
jayro88
Dec 13, 2013 09:34 PM
smoores250
Feb 12, 2010 12:22 AM
alexchavel
21
Jan 6, 2008 01:03 PM
minimumwage
Jun 11, 2007 12:54 AM
