Ford website, it's updated
Old Sep 29, 2003 | 09:05 PM
SavageSam's Avatar
SavageSam
I didn't see the AIC as an option. Let me know if you did.
Old May 19, 2004 | 10:55 AM
khmorse's Avatar
khmorse
Angry
I looked through the Ford website numerous times while configuring the truck I wanted and just now. I did not see an AIC as an option anywhere. The only option that comes close to needing it is the PTO, but it doesn't come up w/a box saying and AIC needs to be added also. I didn't even know that this was an option to consider before I bought my truck. Now I learn if I want it, it will cost me at least twice as much.
Old May 19, 2004 | 09:38 PM
blackhat620's Avatar
blackhat620
AIC is now standard equipment on the 2005 models. Engine block heater is now an option for 2005 except for a few states.
Hope this helps
Old May 20, 2004 | 11:04 AM
taxidriver's Avatar
taxidriver
Ok now what is AIC?
Old May 20, 2004 | 07:32 PM
blackhat620
Originally Posted by taxidriver
Ok now what is AIC?
Auxillary Idle Control. Allows you to set the engine at a fast idle 1200-2500 RPM's for periods of extended idling to prevent damage to the engine. Also used to increase idle if you have Pto operated accessories.
Hope this helps
