test cooling system
Old Feb 10, 2019 | 05:00 PM
tree ape's Avatar
tree ape
test cooling system
i'm thinking of buying a cooling system tester, but not real sure of what would be compatible with my 6.9. adapters? in a doable price range?
Old Feb 11, 2019 | 07:38 AM
Olds64's Avatar
Olds64
You can generally rent a cooling system tester from the auto parts store. Any normal tester should fit on the 6.9l/7.3l IDI radiataor.
Old Feb 11, 2019 | 09:02 AM
RaymondIV's Avatar
RaymondIV
Can't recommend the Mityvac, bought one, used it once or twice, stored it in the basement at a constant temp and after a year or so it leaks air like a sieve between the two plastic
halves.
Old Feb 11, 2019 | 09:14 AM
tree ape's Avatar
tree ape
rental quoted at 2hundred something at autozone. oreilly selling around $80 . if they are universal fit, that's cool.
Old Feb 11, 2019 | 09:51 AM
Olds64's Avatar
Olds64
You get the $200 back when you return the tool. You also might check at different auto parts stores. I'm surprised that Auto Zone wants $200 to rent a cooling system tester.
Old Feb 11, 2019 | 11:17 AM
tree ape's Avatar
tree ape
money back is good, but still a steep dent, however temporary, in budget. i am leaning more toward just buying one. a nice back up addition to the spare toolbox.
donnyonee
2015 - 2020 F150
Feb 11, 2016 02:36 PM
RobbD
Nov 22, 2013 06:55 PM
Chumbucket
Apr 28, 2006 01:14 AM
