Old 02-13-2019, 01:26 AM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
I'd say you have identified your problem for sure.
Still baffled by the stuck injector.
I would be worried that now that O-rings and copper seal have been disturbed you will have leaks. Could end up with mixed fluids and low HPOP pressure.
  #47
Old 02-13-2019, 01:32 AM
Aussiebob's Avatar
Aussiebob
Aussiebob is offline
I knew about the connector problem straight up but figured may as well check every thing while we were so far in. The # 8 is a worry and I want it checked before refit, then I will check the other bank. Thanks for all your help, really appreciate it.
Bob
  #48
Old 02-13-2019, 01:33 AM
Aussiebob's Avatar
Aussiebob
Apparently the # 7 is different from the others?
  #49
Old 02-13-2019, 12:49 PM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is online now
It's a Van Gogh
1 thru 7 should be the same, although the solenoid colors can be different if they are not original. #8 is the "long lead" injector intended to quiet the cackle. You can swap in a regular one with no issues.
Glad the burnt pin showed it's ugly head!
  #50
Old 02-13-2019, 02:27 PM
Aussiebob's Avatar
Aussiebob
sorry I meant the # 8 is a different colour, but still cant get it out.
  #51
Old 02-15-2019, 07:55 PM
Aussiebob's Avatar
Aussiebob
Finally got the # 8 out, lifted the rocker and it slipped straight up. Have carefully replaced all the O rings and cleaned the injectors up. Removed the glow plugs and the ends are a bit brown due to heat, should I give then a gentle wire brush treatment before they go back in? Also I would like to retest the plugs and injectors as they go back in, what's a simple way to test without special tools, use a test light for the plugs but not sure about injectors. Got the new gasket and harness readt to go as well. Aussie Bob
  #52
Old 02-15-2019, 08:49 PM
AllaboutMPG
Looking good. What is the ohm reading on each glow plug? Should be at about 1/2 ohm since your checking them without the harness attached.
  #53
Old 02-15-2019, 09:03 PM
AllaboutMPG
Unless your glow plugs are fairly new I would just replace them since you're this far in already. A buzz test for the injectors will do.
  #54
Old 02-15-2019, 09:49 PM
Aussiebob's Avatar
Aussiebob
Found another problem the rocker at # 8 is damaged where the ball bearing sits in the bottom, will have to replace. Rod OK
Housing rocker
Housing for ball bearing shot
  #55
Old 02-19-2019, 03:04 AM
Aussiebob's Avatar
Aussiebob
To all you guys that sent me experienced info, the truck is back together and running like new. I am so happy to deal with honest people that want to help, what a great team and site!!!! F250 rides again!! now for the next 270000 kilometres.
Thanks so much. Aussie Bob
  #56
Old 02-19-2019, 03:30 AM
AllaboutMPG
Bob, glad you're up and running again. You did all the work and we're just happy we could be of some assistance. Thanks for being part of the brotherhood.
  #57
Old 02-19-2019, 03:40 AM
Aussiebob's Avatar
Aussiebob
Due to the job being easy when you follow the rules I will be doing the other bank shortly.
I see you have air bags I ma looking at them to make my ride safer under load.
  #58
Old 02-19-2019, 08:31 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
Congratulations, it's always good to hear a success story.
  #59
Old 02-19-2019, 08:37 AM
Squirrel13's Avatar
Squirrel13
Squirrel13 is offline
Congratulations Bob! Keep exploring. Your anazong country is on my bucket list. Ill get down under some day!
  #60
Old 02-19-2019, 02:31 PM
AllaboutMPG
I got the airbags when I had a center console boat that set a little heavy on the front of the trailor. Leveled the truck up when towing. I learned early on though not to leave them aired up when not towing. Back end of the truck bounces badly.
Quick Reply: 2004 7.3
