I have a 2000 Super Duty Diesel and when I push the door locks either L or U, on each of the doors you can hear the locks try to activate but they will not move enough to push the pull tab up. Is this common with a truck at 155,000 miles? Is there anything that can be done aside from changing all the motors?
Temperature guage stopped working when the water pump was changed out. I put a new sensor in it but still no workee. I do get a change in Ohms when the sensor is cold to warming up. I touched the leads together that come from the guage and the guage goes to "H" which should mean it is good. I am stumped, any help out there would be appreciated
i have the same problem on my driver side door but if i lock it manual and come back it will unlock with the power key ring i havent took the door skin off to look if there is something to lube up. let me know if you figure it out
99 F250 SD PSD
SCMT
6 inch BDS
Banks Monster Exhaust
AFE Magnum Force Intake
35x12.50 STS Swampers on M/T Classic
Autometer Gauges
