My 7.3 excursion is having a temper problem.
steaming around middle of the engine area. Somewhere near the fuel filter area. But the temp gauge wasn't showing high.
thanks
What does the 'steam' smell of? Coolant or Oil burning? Grab a flash light and start diving into the deep abyss of the engine valley to look for any leaks.
Imy truck sat for 2 weeks, while I found time to replace the glow plugs, o-rings on oil cooler, replaced also some radiator hoses.
I had coolant leak before as well but I replaced the heater control valve, which had the flow direction away from the heater core.
now I took it for a short drive, it got to warm temp, came home and noticed the steam coming middle area.
I'll run it tomorrow to examine when it first starts steaming.
I didn't sniff the stuff too much, but not oily
