Vacuum line help
Old Feb 5, 2019 | 06:27 PM
Robb10's Avatar
Robb10
Vacuum line help
I had to rebuild the stock carb on my truck and like an idiot I pulled vacuum lines and forgot where they went there are also some that a po moved but I want to get it back together by the way the truck is a 1978 f150 4x4 auto with 351m i could use some pictures, the diagrams I see aren’t making sense but that could just be me
Old Feb 5, 2019 | 06:53 PM
RedFordRob's Avatar
RedFordRob
You'll have one small vacuum line that goes to the transmission and one that goes to the distributor . Vacuum can come from the carburetor or the intake manifold . They're all plumbed a little differently. I have one line from the front of my carburetor that goes to the valve cover, a medium sized line. And a large line off my intake manifold that goes to my brake booster. if you still have smog control attached I took mine out years ago. They may use some vacuum. Plug off any holes you don't use
Old Feb 5, 2019 | 07:35 PM
Robb10's Avatar
Robb10
My truck doesn’t have smog and I’m trying to put it back fairly stock for the time being
Old Feb 5, 2019 | 08:44 PM
RedFordRob's Avatar
RedFordRob
Good no smog. I have a 78 with a 302 I'll take a couple of pictures for you basically the same when it comes to the vacuum
Old Feb 5, 2019 | 09:37 PM
RedFordRob's Avatar
RedFordRob
. # 1 is a vacuum port on the carb goes to my distributor.# 2 goes from my valve cover on the right to a plate underneath the carb for vacuum # 3 is the vacuum tree off my intake manifold. The large line goes to my brake booster. One small line goes to my transmission and I forgot to mention earlier one small line goes to my air cleaner for the cold air intake. The other ports on the tree I don't use I just plugged off.
That's a picture of my PCV valve off the passenger side valve cover to the air cleaner. Runs better when the crankcase can breathe also.
it's not pretty but it runs well.
Old Feb 8, 2019 | 04:26 PM
Robb10's Avatar
Robb10
Yours might be a different than mine I’ll have to look thanks for the pictures
smilts
Nov 16, 2015 07:53 AM
MitchD
25
Jan 6, 2011 03:27 PM
82-100
Jan 17, 2009 08:00 AM
sigtauenus
Apr 26, 2007 08:10 AM
CWaters75
Engine Swaps
Oct 18, 2005 02:10 AM
