2020 revealed!
#451
Both SRW and DRW will be lowered.
Ford engineering states:
Front by 1/2"
SRWs Back 1 1/2"
DRWs Back 1"
Around minute 11.
https://www.youtube.com/watch?v=Xq-aEEbdLR8
Front by 1/2"
SRWs Back 1 1/2"
DRWs Back 1"
Around minute 11.
#452
Yeah, myself I won’t buy a left over truck that misses the power and drivetrain or styling upgrades. I’m one of “those” guys who needs the new stuff and would be kicking myself over saving a couple dollars and banking on the old and worn out “tried and true” theory..
#453
Stockpiles of truck and other vehicles are way up, there’s reports of farmers in the Midwest cutting back on purchases due to the ongoing trade war, (John Deere is in the toilet) and there’s constant news of another government shutdown looming. Ford has an opportunity to burn through leftover 2019’s before swinging into the 2020’s, so they’re gonna take it. Where did you think all those PCO’s come from?
#454
Gets pretty expensive to always have the "new stuff". That 2020 will be the old stuff in maybe as little as 2 years would be my guess.
#457
In the TFLtruck video from the first post, the one I reposted, an engineer says the 250 only. In the video you posted another engineer says all. Currently the 250 sits taller than the rest.
#458
There was quite the contradiction by that guy. I’m thinking they are going back to small block for the 250 and large block for the 350.
#459
My guess is in the later video, he corrects himself. I just can't see Ford having 1 1/2" height differential between the two SRW trucks. Again, especially when his stated goal was 5th wheel/gooseneck hookup and ease of access. I guess we'll know for sure when the 2020 Spec guide is released. ForCal is correct that the current F250 sits slightly taller (~3/10").
#461
Any talk of lowering the truck is a deal breaker. If I want a lower truck I'll do it myself. Does Ford think its customer base is represented by those two corpulent old men? You rarely see a 4x4 here in TX that is not leveled out. If cab access is an issue, get running boads.
I bet the real reason is Obamao staybehinds in DOT pressuring Ford about high ride height.
#462
Any talk of lowing the truck is a deal breaker. If I want a lower truck I'll do it myself. Does Ford think its customer base is represented by those two corpulent old men? You rarely see a 4x4 here in TX that is not leveled out. If cab access is an issue, get running boads.
Towing can be difficult with a tall truck.
#464
Don't ask me to find it. The truck will be built soon and you’ll have your answer.
#465
I guess the savings is worth it for some, but makes little sense to me in the big picture. Losing a year’s worth of resale value kills the savings alone, along with missing out on a MAJOR power train upgrade.
This updated model design runs three years.
