Stock Garrett vs Pmax
this question is to those that have done the swap to the Garrett Pmax turbos... Since i Melted my stock one im now trying to decide if i should stick with the stock one or go to the Pmax... i was wanting to hear what you people that are running them feel the Advantages and Disadvantages are to both of them...
My stock turbo when i had rebuilt it previously i installed a billet compressor wheel.. which gained me some additional PSI and seemed like quicker boost response (but cant say for sure on the response since it was having sticking vane problems when i bought the truck but didnt know that was the problem till i ended up with no power at all).. figured id put one in the pmax too if i bought one... and seems like prior to this one freezing up i was told im maxing the turbo out by the amount of black smoke i make at WOT.... (i dont have a coal tune either... just a canned street tune)... highest ive gotten the turbo to was about 36/37 PSI at WOT... both empty and towing that was the highest i got...
The truck is mostly a DD but occasionally hauls heavy loads in the bed and sometimes pulls a 7'x16' cargo trailer (yeah i know not a big trailer for a diesel but i over load it at times too lol).. The only 3 downsides ive heard to going to the PMAX are, slower throttle response when pulling trailers (supposedly not noticed when empty), you need special tuning for the pmax, and the higher cost of the turbo itself... the way i understand it the pressure wouldnt really change just the volume thats delivered to the cylinders would due to the larger compressor wheel.. thats about the only real things ive heard for the pmax...
with the stock one i could keep my current tunes and it would just drop back in (after i change the compressor wheel to the billet one) and the price would be much cheaper than the pmax.... so can yall help me figure out the advantages and disadvantages to both...
ohh the only other thing i know concerning the Pmax is that they have the same drawback as the stock one (the Vane sticking part)..
You're studded, so not much of a concern with the cylinder pressures, but if it were me I'd stick to a stock turbo like what you have. If you really want/need an upgrade, go for the KC 61 MM turbo. It's not overkill and should accomplish what you need it to nicely.
You won't find any unless you go with either KC turbo or one of the others, even then, they typically use the 10 blade.
2004 plus turbines are tame is the best way to put it, since you have a 2003 engine, it means you have a 2003 cam that was designed to support the air flow that turbo produces. You could run the 13 blade, but unless it's from a 2004 turbo, you'd hurt performance and overwork the turbo some. The 10 blade is a larger turbine and 59 mm compressor designed to support the engine and the power it produces.
I installed the Pmax a few months ago on a fairly stock truck. Its noisy but I like it. My only complaint would be lag. There seems to be more lag with this turbo than with oem. Not sure why. Once it kicks in its impressive to me. I have a sxt tuner with TSD tunes and am happy with it. The wheel is whatever came with the Pmax.
Gilbert
Gilbert
Gilbert
Gilbert
it was their 13 blade i was looking for in the videos... their site says they come standard with the 13 blade unless you request the 10 blade... figured with it being "standard" theyre be more videos of them than the 10 blade... but all the videos i found said they were running the 10 blade... i dont mind the whistle.. was just curious to see what the 13 sounded like in comparison..
I can get you an example through a stock exhaust if that would be helpful to you. I have the KC 1.5 with the 13 blade. It's quiet. There is no whistle at idle at all. I can hear the turbo driving around but it doesn't seem any different to me than stock 04+ in terms of sound.
