1994 Ford Explorer
Old Sep 29, 2003 | 02:23 PM
Helpless's Avatar
Helpless
1994 Ford Explorer
Electrical drain=dead battery in short time 24-48hrs. power drain is through power distribution center under hood. When positive cable is disconected from the distribution center, drain stops. I have removed every fuse, relay, and diode to try and isolate the problem. No luck. Does any thing feed straight through the distribution center? Where to look from here? thanks.
Old Sep 29, 2003 | 02:53 PM
Vanhecht's Avatar
Vanhecht
post in the explorer forum sos you can get help from just explorer users...scroll down on the forums page till you see it
