Temporary gutter seam seal???
Old Jan 30, 2019 | 09:50 PM
dziwei's Avatar
dziwei
It's the rainy season and I want to put a bead of something in the gutters and short seams at either end of the gutters to keep water out until spring/summer. Know of anything that will seal for now but peel away when I start to grind out the old seam seal to do it right?
If I don't come up with something I think I will put a tarp over it but that just looks sad and I will likely not drive it even on nice days if I need to deal with a tarp and tie downs...
Old Jan 30, 2019 | 09:55 PM
ford390gashog's Avatar
ford390gashog
Use 3m seam seal, once dry it's easy to sand or remove. Avoid anything silicone as it will contaminate future painting.
Old Jan 31, 2019 | 01:33 AM
dziwei's Avatar
dziwei
I have a tube of body seam seal (3m grey) that I plan to use for the cab to floor interior seam, is that the stuff? would it hold up for several months on the exterior?
thanks
Old Jan 31, 2019 | 01:50 AM
FuzzFace2's Avatar
FuzzFace2
thanks
I have used SEM seam sealer that is the same as the 3M stuff. for the floor panel seams.
Now 3M does make a drip check sealer comes in a small tube like the weather strip glue and that is what I used on my drip rail.
Dave ----
filthy6
21
Dec 6, 2018 08:15 PM
shortride
2015 - 2020 F150
15
May 30, 2018 08:18 AM
Tuna Maniac
Mar 6, 2017 02:32 AM
parr4
Oct 20, 2010 11:33 PM
gangstakr
Jul 27, 2006 08:37 AM
