Weather
Old Jan 29, 2019 | 09:05 PM
  #31
Slowpoke Slim's Avatar
Slowpoke Slim
It regularly makes -30F to -40F here most winters. That's regular air temp, not this fake "wind chill" B.S. that was invented to make people feel better about "being cold". Sometimes that's also the high for the day. We don't make a thing of it. It's called "Tuesday" in ND. So we're kind of chuckling at all the fuss being made by our neighbors to the east right now. We wish them well, to be sure, and I hope they're all tucked in and safe, but meanwhile, we'll just be truckin' on.
My truck sits outside all the time. The only time it sees the inside of a garage, is when it goes in for an oil change or a tire rotation. It does have a factory block heater. I've seen it. I've never plugged it in. Don't need it. The only issue I've ever had is a year ago when my factory OEM battery died on me (it was -30 F that day iirc - and again, that was true air temp, not this "wind chill" fantasy b.s.). I replaced it with an AGM battery and haven't had another problem.
I have not had one. single. issue. with my truck other than the OEM battery crapping itself in winter ( a year ago). But, it's also one of the reasons I bought a gasser truck. To have fewer issues in the cold. If I lived in a southern state, I wouldn't have been concerned about it.
Old Jan 29, 2019 | 09:48 PM
  #32
wrvond's Avatar
wrvond
Originally Posted by jiminn
anyone know if there are tank heaters in the fuel tank and DEF tank?
Fuel tank = no
DEF = yes - however, the heater only runs while the truck is running. Your DEF will freeze in the tank. The heater will eventually thaw it. Do not top it off, leave room for expansion.
Old Jan 29, 2019 | 09:54 PM
  #33
stufarmer's Avatar
stufarmer
Here in Tampa I actually wore long pants today .. I hate long pants ..!
Old Jan 30, 2019 | 06:03 AM
  #34
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
And you notice how the medial is hyping up all these winter storms just in the past couple years, and even giving them names like hurricanes? Ridiculous. Anything to get the sheep all worked up for ratings and for something to talk about...
Old Jan 30, 2019 | 06:32 AM
  #35
llmflyfisher's Avatar
llmflyfisher
Hard to imagine what -60* feels like. Here in S TX if it gets under +60* it starts to get a little too cool and we freak out if it gets under +30*. I think I would die if I had to try to live and work in temps as cold as what yall are saying here.
Normal uniform here is flip flops, shorts, t shirt and eye protection with more sun protection if out fly fishing the lower laguna madre. I don't think I could survive in temps that cold. Forget my truck.
Old Jan 30, 2019 | 07:02 AM
  #36
Desert Don's Avatar
Desert Don
So, what is the difference between -40 in ND and -40 in the rest of the world?
Just move to ND and find out!!
The livestock still MUST be fed and watered, life still goes on.
The rigs still keep drilling for oil, life still goes on.
The trucks still keep hauling. Life goes on
The mines still keep producing coal. Life goes on.
The news media could freeze up and no one would notice!
But.............when I retired there WAS a reason I propmtly moved to AZ!!! And you will NOT hear me complain about the heat......dry or otherwise! LOL
Old Jan 30, 2019 | 08:22 AM
  #37
dksmith17's Avatar
dksmith17
Master Trooper Glen Fifield
@ISPLowell2I-65 is quickly becoming a parking lot with broken down semis. Common problem seems to be fuel filters freezing and fuel gelled. Please reconsider travel today. It’s extremely dangerous for everyone. Calls for service are numerous #DeepFreeze #ArcticBlast
Old Jan 30, 2019 | 08:48 AM
  #38
Poncho450's Avatar
Poncho450
Originally Posted by wrvond
This would do more to prevent driving away with an extension cord hanging from the front of your truck than anything else.
I find it's always a good idea to perform all outside activities before getting in. Much less likely to forget something important.
I've done this on my Bobcat more than once. Fortunately it's always come unplugged and not yanked out the block heater cord.
Old Jan 30, 2019 | 08:54 AM
  #39
Poncho450's Avatar
Poncho450
Originally Posted by JH350
Running does help but they will run and still gel from my understanding
They sure can. I drive box truck for a USPS contractor part time. All International straight trucks. We've had a couple of almost new trucks that started right up in below zero weather because they were plugged in at night. But there have been times that the fuel heaters didn't work and they gelled up while under way at highway speeds. The fuel had been treated with white bottle Power Servics, which I don't really have much faith in at those temps. The usual solution is to change the fuel filter and get some Power Service 911 red bottle stuff going through the system.
Old Jan 30, 2019 | 09:03 AM
  #40
MooManChu's Avatar
MooManChu
I'm an Idiot
Being a newbie first winter with my F350, I kept reminding myself that I need to unplug the first time. Got up for work....Remote start warmed her up, jumped in the truck and drove off....realized I had not unplugged around lunch..
Going forward, I have a low-tech solution...post it note on steering wheel.
Than it hit me..Why don' they have magnetic connectors and contact setup for these block heater plugs? I've come up with a great idea right?. ..Nope..someone on kickstarter beat me to it.
First gen..
https://www.kickstarter.com/projects...l-plug-evolved
v2
https://www.voltsafe.com/
Not sure this would hold up in our salt-ridden NE Ohio winters...and post-it Note hell of lot cheaper
Old Jan 30, 2019 | 09:18 AM
  #41
xxxsherpa's Avatar
xxxsherpa
Just hang the extension cord on the drivers side mirror.
Old Jan 30, 2019 | 09:23 AM
  #42
MooManChu's Avatar
MooManChu
better yet...
I leave and come home in the dark...really bad if I dont see the cord
Old Jan 30, 2019 | 10:11 AM
  #43
redford's Avatar
redford
FTE Leadership Emeritus
-23F actual air temp this morning at my office.
There is a refreshing lack of mosquitos and wasps outside.
If your truck didn't start, you need to focus on your maintenance.
Old Jan 30, 2019 | 10:39 AM
  #44
JH350's Avatar
JH350
-40 on the truck this morning and the truck sits outside and fired right up. i do plug it in as well. even my gassers up here i plug in if i can. much easier on the vehicle. -62 windchill value this morning but really anything below -30 is cold and dont feel a difference. when you lived withi it your whole life its just another winter day, the media is horrible, not the only place in the world it gets chilly. to say it never gets this cold is ridiculous. we see it every year. i do start the diesel a couple times a day when i am at work though just to keep it moving easier. alot of cars were not liking the cold and getting jumped last night and this morning.
Old Jan 30, 2019 | 07:28 PM
  #45
GMoney1121's Avatar
GMoney1121
Originally Posted by SUPERTRUCKERS
1st: Stay warm!
2nd: I'd like to see some cold start videos tomorrow with temps that low...
Ask and you shall receive. Here’s a video of mine this morning.
