Mass Air Flow Sensor?
Old Sep 29, 2003 | 10:29 AM
Bluesxman5's Avatar
Bluesxman5
Question Mass Air Flow Sensor?
IU have a 97 Ford Explorer V6 SOHC. My check engine light went on and it's giving me an O2 message and several misfire codes. The car is "bucking" and "lurching". It shakes when I accelerate as well. It seemed to me it was an airflow issue. I read about cleaning the mass air flow sensor so I did that. I didnt completely take it out. I just sprayed some contact cleaner on it through the tube. My problem is still there. Would I be getting a mass air flow sensor code if that was the problem? any help would be greatly appreciated. Thanks.
Old Sep 29, 2003 | 06:54 PM
Go Aweigh2452's Avatar
Go Aweigh2452
MAF is very sensitive to sealants such as silicon. In fact using a silicone sealant when installing a K&N air filter is enough to kill it. SOunds like yours is dead and you ensured its burial by spraying it with contact cleaner... Borrow a code reader and check out the MAF.
Old Oct 2, 2003 | 08:10 AM
silvapain's Avatar
silvapain
Eletrical contact cleaner is specifically designed to clean sensitive wiring without damaging it. I have cleaned my MAF a couple of times with contact cleaner, and it works fine.
Old Oct 3, 2003 | 09:16 PM
CobraXP's Avatar
CobraXP
Yes, you will get some type of code if the mass dies. The prongs on the mass air sensors are tiny and can break very easy. I've broken one with a q-tip the first time I tried cleaning them.
I would recommend going by Auto Zone. They will read the codes for free. See if you have any codes coming up, and go from there...
Old Jan 15, 2004 | 11:50 AM
TartanDon's Avatar
TartanDon
So what is the best way to clean a Mass Airflow Sensor? I read somewhere that Ford say they can't be cleaned. Would a can of Air Duster do the job or is contact cleaner the stuff to use?
Old Jan 15, 2004 | 03:13 PM
maa139's Avatar
maa139
I've had good luck with carb cleaner and a toothbrush. Ford says that you can't service it, but you can. The hardest part is getting the tamper resistant torx screws out. I've seen the TR bits at pep boys. After I got the sensor out, I saturated the tooth brush with carb cleaner and VERY VERY GENTLY cleaned the filaments. I embeded the filament in the bristles and scraped the brush back and forth. The sides of the bristles were actually doing the cleaning, not the tips of the bristles. After that, give the filaments a good spray of cleaner and then set it aside for 10 minutes or so to dry. Then just put it back in. All together, it takes me about 15 minutes to do this.
Good luck.
Old Jan 15, 2004 | 04:14 PM
TartanDon's Avatar
TartanDon
Thanks for that advice Maal39, the idea of using a toothbrush sounds a bit scary so I'll look for one with soft bristles! I'll have a go this weekend if it's not too cold.
_________________
97 Explorer 4x4 SOHC
4.0L V6
Old Jan 15, 2004 | 05:53 PM
Jharger's Avatar
Jharger
I've not had the need to tough the 2 wires on the MAF with any brushes to clean them. Just spray with carb cleaner and it works fine.
Old Jan 16, 2004 | 06:05 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I prefer to use a short bristle artist paint brush and carb cleaner. Keep working the brush/cleaner around until the MAF is clean then give it one final spray of carb cleaner followed by a light blast of air. The filaments of the MAF are delicate; be gentle and they will not break.
Old Jan 16, 2004 | 12:25 PM
TartanDon's Avatar
TartanDon
Thanks JHarger and CowboyBilly9Mile (love that handle)
Got my carb cleaner and plenty artists brushes. I'll treat the MAF with care. Let you know how I get on.
TartanDon
DeeDubz
6.7L Power Stroke Diesel
17
Jan 29, 2017 07:32 PM
jerkypants
Oct 29, 2011 09:17 PM
Johnlwlr
May 3, 2011 07:30 AM
SWA2004
2004 - 2008 F150
Mar 26, 2010 08:41 PM
greglaban
Oct 12, 2007 09:46 PM
