2000 Explorer computer module location
Old Sep 29, 2003 | 10:01 AM
Dru's Avatar
Dru
Cool 2000 Explorer computer module location
I recently purchased a used 2000 Explorer Eddie Bauer and the previous owner did not have the factory set 5 digit number for keyless entry soooo I accessed your forum thru Google and got some sketchy ideas on where this module might be located and wanted to share my experience to others that, may in the future, have the same problem. The computer module is located in the tire jack access panel, rear storage left. When you remove the panel the computer module is the white plastic module slightly forward. This module is held in place by a brass hanger with one holding bolt visible but removing this bolt does not free up the module so forget about trying that. In this compartment there is one other black plastic module held in place by two accessable bolts, remove the bolts and lower the module to give you a better area of vision. Now, and you'll need someone with good eyes, take the jack and GENTLY pry the plastic interior storage trim away from the white computer module and look into the space with a bright lite, this will only give you at most a couple of inches of space. Taped on the side is a label with the 5 digit code printed in the middle of the label in bold digits...that's your code. I wear glasses and was able to see the numbers, it's not easy though, but be patient. Just wanted to share with others, great forum btw.
Drew
Old Sep 29, 2003 | 10:10 AM
Billy177's Avatar
Billy177
if it is a 2000 you will probrally have to call the dealer but if there is a code it will be on a module in the tire jack compartment
Old Sep 29, 2003 | 12:36 PM
Dru's Avatar
Dru
That's what I said in more detail above...Thanks.
Dru
Old Jun 25, 2006 | 10:31 AM
dmack86's Avatar
dmack86
Thumbs up You are the man
Dru I have a 2000 explorer that I purchased about a month ago and no one could give me the right info on this subject. Well I read your info and I found the code. Thank you
Old May 3, 2008 | 06:42 PM
kevcbm's Avatar
kevcbm
Dru - Thanks i just found mine on a vehicle that I just bought. Nicely written!
Old Oct 25, 2012 | 07:53 PM
jarndt's Avatar
jarndt
Talking re: 2000 Explorer computer module location
Thank you very much Drew. I did not have to take the black module out I just adjusted the tire iron to pry the covering out enough to see and it was very hard to read. I got though thank you!!!!!!!!
jarndt
Old Oct 25, 2012 | 08:21 PM
White 97 xlt's Avatar
White 97 xlt
Wow!!! I can't believe they left something in the same place for several years, I had a 91 before and it was in the same location, and have a 97 now and guess what, still there right over the left rear wheel.....
jnobles06
Aug 25, 2018 04:19 PM
1956MarkII
203
Jul 23, 2018 03:10 PM
FourXFord2
Dec 17, 2016 08:49 AM
TRENT310
Oct 26, 2014 02:46 AM
derek4343
2009 - 2014 F150
Dec 29, 2013 10:51 PM
