Sponsored by: Real Truck
2008 F350 ODD ENGINE SHUTTER?
Old Jan 26, 2019 | 08:44 AM
CAT731's Avatar
CAT731
4wd Low
I have an 08 f350 5.4L. I just replaced the battery, alternator, voltage regulator, and serpentine belt. Truck runs great but I’ve noticed an odd issue. It seems that only when the truck is in drive, while stopped with foot on the break, every couple seconds there is a slight shutter that lasts for maybe half a second. RPM jump very slightly for a second then back to normal. When in park or neutral no shutter at all. Only in drive while stopped at a light. And it only started doing this AFTER I had the work done. Any ideas? Thank you very much in advance!
Old Jan 26, 2019 | 09:41 AM
Djosbun's Avatar
Djosbun
First of all: CHANGE YOUR TITLE. This is not an emergency and not even a severe problem. More people will read your post with an appropriate title.
More than likely you have a vacuum leak. Use some propane gas or starting fluid and spray around the intake manifold and your vacuum hoses. When you hear the rpms raise, you found your leak.
— Dave
Old Jan 27, 2019 | 04:06 AM
cmaupin's Avatar
cmaupin
I would consider changing out the plugs, Or the cops. or both my 5.4 would do it when in drive and down then road
good luck
Jcstanton
Aug 30, 2018 08:17 AM
tjc transport
13
Aug 28, 2016 03:15 PM
bgodkin
25
Mar 14, 2015 12:22 PM
Marty's 97 F-150
1997 - 2003 F150
Apr 6, 2008 10:23 AM
Demicon
Feb 23, 2005 01:39 AM
