5th Wheel Toy Hauler ??
The real world pin weight on the 349 is NOT under 3k....totally empty and no options, maybe, but not loaded. Add some propane, generator, and stuff inside, and you’re over 3k. My weight sheet says my dry pin weight is 3011, it’s more than that now. The GVWR on mine is 16,500 and I’m pretty sure the ‘19’s are 17k.
I use the Andersen hitch as well and really like it. Very easy to move around.
Received 6,693 Likes
on
They do make a 5th wheel but it isn't a toy hauler.
Desert Fox by Northwood Mfg, but it's a TT not a 5th wheel. They make their own frame.
Hey Stufarmer, I know this has been mentioned before but this might work for you. They make a really good trailer and it's all aluminum. I saw their operation and it's pretty impressive. They actually drove a forklift on the rear door and it didn't buckle or bend. If I end up going the toy hauler route I may get a bumper pull but it will most probably be an ATC.
Also, the '19's are supposed to be equipped with triple axles.
ATC Toy Hauler Models
It does fine, but you know it’s back there. I’ve towed it in some hills and windy weather and it tows better than my previous 30’ Work n Play bumper pull TH. The 349 is the max weight/size I’d go with a SRW, any bigger and I’d get a 450.
Here's my setup. Forrest River Stealth 2816G behind my 1997 F350 7.3. Carries dirtbike, gear and all the water I could ever need. 150 gallons! Will also fit a 4 seater SxS when the time comes but that would limit that 150 gallon water thing. But I'm learning the places to fill on the way to destinations so I don't have to haul that much water from home. I use the Andersen hitch. Highly recommend!
Stealth SA2816G - Stealth Fifth Wheels Toy Haulers by Forest River RV
We looked at a few of the other $125k+ 5er's, cost more than my house put were pretty lol
Jhernandez1304
Fifth Wheel & Gooseneck RV Towing
52
08-16-2019 03:00 PM
