C5 kickdown rod
Old Jan 24, 2019 | 04:54 PM
matthewq4b's Avatar
matthewq4b
Even if it does not work the controls still need vacuum to operate the zone doors, defrost / dash vents / floor.
Yes do so. Because he has AC and I cant remember were the vacuum tank gets it's supply from. Check the tank / metal juice can for leaks, mine had rusted pin holes so the motor had a vacuum leak.
Dave ----
IIRC it is supplied from the distribution manifold and not the intake.
Old Jan 24, 2019 | 06:51 PM
FuzzFace2's Avatar
FuzzFace2
Well then that could be why he could be getting a bad / low signal if the vacuum line to the trany was to the tree on the fire wall.
Or are you talking of a different manifold?
Dave ----
Old Jan 24, 2019 | 07:02 PM
matthewq4b's Avatar
matthewq4b
Dave ----
Nope we are totally on the same page, my thought is something on the tree on the fire wall is leaking or the tree is it's self might be leaking/cracked.
Old Jan 24, 2019 | 07:23 PM
1981 F100's Avatar
1981 F100
Thanks,I'll check it over
Don Vito
Mar 9, 2017 10:53 AM
d-day
13
Apr 7, 2014 12:21 AM
Becky_is_a_66
Dec 12, 2012 06:06 PM
65fordguy
Jan 20, 2009 11:55 AM
luvtruck
Feb 16, 2000 07:01 AM
