4x Transit
4x Transit
I been considering making my next work truck a van. A 4x conversion, Mid roof, regular length, Transit.
Anyone actually own one?
Quadvan or Quigley? I am just looking for input.
It also seems that the lead times are super long. I did look on Ebay for used vans, but they seem to be older and super high mileage.
Any input would be greatly appreciated!
Thanks in advance.
Thanks in advance.
I've always liked the idea of a 4x4 van but a conversion costs a lot of money to pull off. Quigley will not convert used vans, most likely because if they are brought a worn out van and convert it, the existing problems become their potential problem and liability.
Have you looked at the 4x4 Sprinter? It is available from the factory, and they are now being built in the US. A full factory vehicle has the undeniable advantage of complete warranty and dealer support.
George
George
On another site that deals primarily with van conversions as small RV's there's a lot of talk and vendor recommendations for Transit and Sprinter 4x4 conversions---look into Sportsmobileforum.com and see if anything there is helpful. Most members there are very eager to answer questions and share their experiences too.
HTH
HTH
been looking long and hard at a 4x4 van, since I have a large family, pretty much need a 4x4, and would like decent towing. Along with head and shoulder room requirements I have, I would be limited to the Ford Expedition or a 4x4 passenger van.
The 4x4 passenger van will definitely hold its value better. All options run about the same price; 4x4 converted van, 4x4 Sprinter, Expedition. The Expedition will drop in value quicker. The Sprinter doesn't have a dealer near-by, and I hear some not so good things about that engine. The Sprinter dealer wasn't talking them up either.
pros for the expy is that a 2 year old one will be available and save some coin, it will fit in my garage, probably better mpg than the vans, and better tow rating. Better options if I want to do something stupid with a lift and what-not as well.
I heard a rumor that 2020 will bring the 10 speed and might bring a 4x4 oem to the Transit. I am not desperate yet, so will probably wait and see.
I would probably do Quigley if converting because they are the trusted name, and have more to loose if they screw it up. They also likely put a bit more into R&D than the small players. I saw some new GMC Quigely's purchased by FedEx when I worked for a GMC dealer. They looked like quality. Shipped right to the dealer and that the removed parts shrink-wrapped in the back on a pallet. I think that is an extra cost option.
Read some interesting things about the trasit AWD. The main one being no traditional bolt on transfer case. Sounds like it's more like a 2wd transmission with something like a PTO bolted onto it to drive the front axle.
If they make the low gears low enough in the 10 speed, the lack of low range wouldn't matter so much. I figure the van is the test mule for this tech. I wouldn't be surprised if all f150s and expeditions use this in a couple of years, assuming it works in the vans. It would make 2wd and 4wd much more similar, and that saves money.
Joe McDuff
10-15-2005 06:37 PM
