Help
Old Jan 20, 2019 | 11:42 PM
Melder232's Avatar
Melder232
Help
How do you check the sensor for the water in fuel separator so I don’t buy that too and it not be the issue
Old Jan 21, 2019 | 03:04 AM
seville009's Avatar
seville009
Non-technically, drain the bowl and see if there’s water. If there is, and your sensor didn’t go off, it mught need to be replaced.
Or pour a gallon of water in your tank to see if that triggers it (ha ha .....don’t do this)
Old Jan 21, 2019 | 08:17 AM
Melder232's Avatar
Melder232
I did that and I’ve replaced the filters and I’ve even took the sensor out and cleaned the post on it.. this all happened after I left a carwash
Old Jan 21, 2019 | 08:42 AM
Kegme13's Avatar
Kegme13
How much fuel have you drained? Can you still see water settling in the bottom of your sample? I only have a basic understanding of how the sensor works, but I'm thinking you could pull that sensor, dry it all off, and use a multimeter to see if there is continuity at the plug. If continuity is present when it is all dry and removed from the truck then I would think its safe to say that sensor is toast.
bryanzzz
6.4L Power Stroke Diesel
May 15, 2015 02:54 PM
Dyllan78
May 7, 2011 01:48 PM
BIG J82
Apr 15, 2011 03:05 PM
ttttmaxx
Mar 7, 2008 02:13 PM
tex25025
Mar 6, 2007 11:22 AM
