So, there's a local guy here, is selling a 460 with DV3E heads. It's out at his buddy's farm, but he swears pretty solidly that's what they are. Are there actually such heads?
I'm assuming that's a typo. They should be D3VE heads rather than DV3E. That's what ford put on the 460's starting in '73. I have a set on the 460 that came in my '75 F150.
It will be a low compression deal but a good starting point to make good power if that's what you're after. Those heads will work fine with higher compression pistons.
