2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
My new front bumper
Old 01-18-2019, 12:25 AM
IamLee's Avatar
IamLee
IamLee is offline
My new front bumper
Here are few pix of my new Bodyguard bumper. The pods are Rigid SAE and amber duallies, tthe 30” amber LED
is Baja Designs S8 and the winch is a supewinch EXP 12K synthetic. I had bodyguard powdercoat it primer grey then I sprayed it to matched my truck.
Old 01-18-2019, 12:33 AM
IamLee's Avatar
IamLee
IamLee is offline
A couple more pix
Old 01-18-2019, 12:38 AM
wicked 2018's Avatar
wicked 2018
wicked 2018 is offline
Got a side profile shot. Trying to get an idea how far it sticks out. In the market for a winch bumper myself.
Looks great
Old 01-18-2019, 12:39 AM
KCRebel's Avatar
KCRebel
KCRebel is offline
Can you share the info on the bar lights and grill mounts? Looks like an awesome setup!!
Old 01-18-2019, 09:39 AM
IamLee's Avatar
IamLee
IamLee is offline
Looks great
Old 01-18-2019, 09:44 AM
IamLee's Avatar
IamLee
IamLee is offline
the top light is a black oak led and the bottom is a vivid made in China. Both are very bright! I started a thread last year titled “ I cut up my Platnum grill”, it has more info. I’m glad to answer any questions you might have.
Old 01-18-2019, 09:58 AM
KEVPOPPAPUMP's Avatar
KEVPOPPAPUMP
KEVPOPPAPUMP is offline
Out of curiosity, regarding the Fog Lights, were you able to use the existing factory Fog Light wiring to connect the new Rigids?
I've been looking at new front bumper options and have been wondering about connecting the Fog Lights.
Old 01-18-2019, 11:44 AM
wicked 2018
Originally Posted by IamLee
Thank you!
Old 01-18-2019, 01:34 PM
CACRanger's Avatar
CACRanger
CACRanger is offline
Does your truck have the ACC? If so, is it still functioning correctly and where does it mount? Can you get a close up picture of that?
Thanks,
Chris
Old 01-18-2019, 04:21 PM
IamLee's Avatar
IamLee
IamLee is offline
yes, I used the original factory wiring for the rigid SAE led’s, but I wired the outer amber led to a upfitter switch. I think too much draw to wire all four pods to the factory wiring.
Old 01-18-2019, 04:23 PM
IamLee's Avatar
IamLee
IamLee is offline
Thanks,
Chris
yes and yes it works perfectly.
Old 01-18-2019, 06:56 PM
stufarmer's Avatar
stufarmer
stufarmer is offline
I like it .. a lot.
Old 01-18-2019, 07:52 PM
Norris McCarty's Avatar
Norris McCarty
Norris McCarty is offline
I've been running all four Rigid LED fogs thru the factory fog switch for 5 months without a problem.
Old 01-18-2019, 11:44 PM
IamLee's Avatar
IamLee
IamLee is offline
The wire gauge is much thinner then the rigid’s, I personally wouldn’t trust it. The sure answer is to figure the amperage and compare. I didn’t do that.
Old 01-19-2019, 09:58 AM
skanj0's Avatar
skanj0
skanj0 is offline
If you want to not have to worry about it all, then just use the oem fog light wire to trigger a relay that then allows power to flow to the Rigid fogs. Then they act as if they are being powered by the oem fog light circuit but really they are being powered by a standalone ciruit with its own fuse.
Quick Reply: My new front bumper
