Hard starting
Old Jan 17, 2019 | 12:49 PM
mtntop1's Avatar
mtntop1
Hard starting
Here's my problem,for over ten years when the engine is at operating temp and not running for thirty minutes of more it is hard to start.It will crank for about 5 seconds then start.When it is cold it starts right up.There are no codes,fuel pressure is 35lbs idling 40 to 45 lbs at 1500 rpm,35lbs after engine shutoff no noticeable pressure leak down.I replaced all eight fuel injectors.Two of the old ones would leak down to zero in 30 minutes ( the reason I went with new Mototcraft injectors).Tune ups don't help and the fuel regulator checked ok.If anyone has any suggestions I would be appreciated.Thanks in advance.
Old Jan 17, 2019 | 02:12 PM
sandymane's Avatar
sandymane
If it has been a while since you ran codes consider this. There are so many things that could cause your issue that I would run codes now, even if no CEL, and see if you can get a start in the proper direction. Could be battery or alternator or starter or engine coolant temp sensor ECT or other things. Sandy
Old Jan 17, 2019 | 11:31 PM
technobabble's Avatar
technobabble
If it's never been replaced, I'd replace the ECT just for piece of mind. Had 3 go out - 2 mustangs and an F150 .... same part. The good ones seem to die around the 20 year mark. I had a similar hard start when warm issue and no codes were thrown. In my case, it was a small vacuum leak (hose cracked). Was throwing off the MAF and computer just enough to give a harder than normal start when warm, but otherwise ran normal. Engine cold, there was probably little to no leak, but as it warmed up the leak got worse.
Old Jan 18, 2019 | 07:50 AM
Mbizzal's Avatar
Mbizzal
I have been chasing this issue for years. No codes, fuel pressure good, truck runs great other than the hot start issue. Once the truck does start I see black smoke coming from the tail pipe. To much fuel?
I was also told to change the ECT but I was given the wrong part and haven't gotten around to getting another one. The ford dealership will have to order one.
1979 300i6
Jan 23, 2016 08:35 AM
Herschel Miller
Sep 7, 2012 12:35 AM
AzPete
1978 - 1996 Big Bronco
Sep 3, 2011 12:19 AM
lnbrgr78
Apr 13, 2005 03:21 PM
kag
Aerostar
Mar 24, 2004 11:02 PM
