edelbrock carburetors
Does any one know any thing about 1405 edelbrock carburetors? I found gas laying around the secondary weights and it has been running a little rich lately but other wise it is fine. Is this a common thing? Is this normal? What goes wrong in their to cause this? What can be done to fix this? Thanks for any help.
Nothing out of the ordinary about AFB's. These are actually on the basic side. Is the choke and unloader functional? Got a good filter upstream? Junk can cause the needle and seats to stick open, and they will flood just like any other carb. One thing to remember is that the carb has two bowls, two needle and seats, and is split side to side. I have seen the bowl gasket hit the floats and keep them from lifting all the way and closing the needle and seat before.
Other than that, they tend to be pretty trouble free. Holler if you have any other questions.
Adios,
Brett
Adios,
Brett
57 Ford
Let us know what you find. I am running the a 1405 or 1406. Don't remember for sure. Every now and then it appears to be blowing fuel past the needle and seat. I am far from an expert on them. Edelbrock says they are pretty sensitive to excessive fuel pump pressure. I guess they like 6 pounds or less. I may invest in the offroad needle and seat kit. Thinking perhaps it may be better quality. Maybe not. Never had the lid off mine yet, it's new but way out of warranty from my long build time.
fenders, at least you know about what model you have. Is there a number on the ed carb to tell me what model I have? I bought the truck with it on there. As long as we are on the subject; some guys say the edlebrook needs to be adjusted by a trained tech with a vacuum guage. True?? If not, does anybody know how?? Thanks, John
The model number should be stamped on the front edge of the front left mounting flange. Magnetti-Mirelli (Weber USA) actually makes AFB's for both Edelbrock and Carter (Federal Mogul).
Good Luck!
Brett
Hey Brett, I can adjust the idle speed, no prob, but the afm screws are a different story. The instructions from Edelbrock say to rich the mixture until you get the best rpm. I did that but the rpm stays constant. Should I be turning to the lean mix first so that the rpms have a chance to change? It's as if there is no room for improvement. Maybe mine are already adjusted to where they should be. The instructions say to not turn any further once you have reached the best rpm. Thanks, John
John
Some carb tuning is done seat of the pants. Adjusting for max idle vacuum is a good method. Another is to take the AFM screw in until the RPM begins to drop. Then back it out for max RPM and then about a quarter turn more. You'll have to go back and forth between the two AFM screws a couple times.
Also, the AFM circuit does next to nothing for anything other than idle. If you have any off idle issues, see the Edelbrock adjusting guidance to dial the carb in to your engine. It's a rodder friendly carb.
Good Luck
Good Luck
