Plug on rear end
Old Jan 12, 2019 | 01:28 PM
Tex51's Avatar
Tex51
Question Plug on rear end
I bought a rear end out of a 2002 F-150 truck and it is disc brakes. I want to put it in my 69 Ford F-100, but there is some electrical wires on the pumpkin and I don't know what they are for. The rear end numbers V828A, 3 55 88 1K18. I can tell by the numbering that it does not have a locker. That is something I will add, but the wires on the pumpkin have me at a loss.
Old Jan 12, 2019 | 04:28 PM
Franklin2's Avatar
Franklin2
They are usually for the speed sensor. They use this for the speedometer on the newer trucks, as well as the ABS system, the cruise control, and the engine computer looks at this signal to know road speed so it can control the transmission among other things. If you are going to run some sort of fancy fuel injection on your old truck, and it needs a vehicle speed sensor, you can more than likely adapt this sensor to that system.
Old Jan 12, 2019 | 04:36 PM
Tex51's Avatar
Tex51
Thank you Franklin2, No fuel injection just a plain 390 with roller cam, aluminum heads, intake, and holly 4V carb. I did measure the width of the leaf spring brackets and they are 4.5" wider that what my 69 is. I think I will need to move the brackets in 2.25" on each side and then I did not measure the full length of the rear end but if it is 4.5" wider that my 69 then I will need to order rims that have a set back of 2" for this rear end. The fun of upgrading your old trucks.
Tex51
19
Nov 14, 2018 08:26 AM
junkyardjeff
May 30, 2015 08:24 PM
96Aerostar
Aerostar
Jun 8, 2014 11:05 AM
Red Cobra
Feb 21, 2009 03:23 AM
Snowking
Sep 25, 2006 09:58 PM
