Rim Size Question
Old Jan 9, 2019 | 11:06 AM
PhilD13's Avatar
PhilD13
Rim Size Question
I have a '92 F350 Custom 4 x 4 Dually that currently has Accuride 28512 16 x 6K 8H – 6.50" 5.35 Max load 2500 lbs - 65 psi rims all around.
The rim for the spare that I have is a Accuride 28333 16 x 6K 8H – 6.50" 5.00 Max load 2200 lbs - 65 psi
The wheel offset between the two are .35" which is a bit more than 5/16 difference Before I have a tire mounted on the spare rim, will the offset difference cause any issues with tire clearance on the dualls?
Old Jan 9, 2019 | 03:16 PM
Briansshop's Avatar
Briansshop
I can't see there being a problem.
Old Jan 9, 2019 | 07:29 PM
PhilD13's Avatar
PhilD13
Ok. Thanks for the input. It's going to get a 235/85R16 E load rated tire to match the others.
johndeerefarmer
Sep 13, 2016 09:53 AM
davbell22602
Apr 11, 2012 09:38 PM
66flareside
Sep 14, 2008 10:03 AM
92_FlareSide
Sep 5, 2006 10:02 PM
Hele On
Apr 22, 2003 05:24 PM
