Curiosity question about pcm
Old Jan 7, 2019 | 05:33 AM
Shovelheadrob's Avatar
Shovelheadrob
We all know how easy it is to chip our trucks, since Ford already put the connection point on the board in the PCM, what was the original purpose of this? Was it not possible to update the pcm through the OBD11 port as with all modern stuff? Is it a leftover from before the introduction of the OBD11?
Just curious as to the history!
Old Jan 8, 2019 | 01:56 AM
'88 E-350's Avatar
'88 E-350
I think that's there for the original programming when they build it. The OBD port wouldn't exist 'till the vehicle's harness is installed.
Old Jan 8, 2019 | 02:14 AM
Shovelheadrob
I'd have thought that the pcm would be pre programmed?
Old Jan 8, 2019 | 02:48 AM
pirate4x4_camo's Avatar
pirate4x4_camo
The program was loaded onto the chip after the circuit board was assembled and right before being installed in the truck for the simple fact the programming was always a work in progress. Back when these trucks were the current offerings if you took your truck in to the dealership for service you would have to request them not to install the lastest pcm update. It was standard operating procedure at the dealer to install the most current programming. Dealer did updates via OBD port but has the capability to do it out of the truck via the connector when installing a new pcm for example.
Old Jan 8, 2019 | 11:20 AM
Shovelheadrob
Thanks, that makes sense, some things don't change, my Ford Transit work van still gets "updated software" still & it's 6 years old now.
1Fastboy
Computer Chips & Tuners
Dec 21, 2020 10:52 PM
Riverboy460
Dec 31, 2013 11:22 PM
broncxl302
Feb 13, 2012 11:55 AM
potsiewebber
Jul 21, 2009 05:43 PM
watermanh
Sep 1, 2005 01:45 AM
