Looking for 8.8 gear sets
Old Jan 6, 2019 | 09:04 PM
Richard A. Coyle's Avatar
Richard A. Coyle
4wd Low
I am looking for some odd gears for a 8.8 rear end: I am looking for 2:26 and 2:47 gear sets.
Thanks for reading this.
And any help.
Rich
Old Jan 6, 2019 | 09:25 PM
ford390gashog's Avatar
ford390gashog
Best you are going to find is a 2.73:1 as used in 1986 mustangs.
Old Jan 7, 2019 | 06:01 AM
Richard A. Coyle
4wd Low
Thanks for reading and responding: My plan is to install a 6R80 transmission, with its very tall lower gears I figure I will have the same or slightly better take off. And get great MPG on the highways in top gear.
Here is the RPM/speed charts of say a Ford Crown Vic with its stock gears and a 6R80 transmission compared to a 2:26 and 2:47 rear ends.
And yes I am aware of the possible lugging of the engines, but I will be running stock engines which in my testing have enough torque to pull my car at speed and RPM.
My ideas that I worked out so many years ago are coming to life in a number of ways, first was the Chevy TPI, all modern Ford Crown Vic (4.6, which is smaller that the classic 289) and many vans and trucks with the Ford Modular engine (4.6 and larger) have been running Ford's version of a TPI.
Now the Corvette C7 with its high performance 6+ litter engine running Chevy's version of the 6 speed transmission is running a 2:47 rear end and gets 29MPG with it...in a car that can do 0 to 60 in under 4 seconds and a top speed of over 170MPH.
I think it works.
Rich
Old Jan 7, 2019 | 12:05 PM
xlt4wd90's Avatar
xlt4wd90
Better acceleration is part of having a transmission with more lower gears. The other is an effort to keep the engine running in its optimal range for power or efficiency. I'm guessing that the 6R80 needs a computer to control it, and its computer either works with, or is part of, the engine control computer. I'd be curious to see how it would work if you did not keep the engine and transmission together with their computer. But yes, if the engine can generate enough torque to drive the really tall gears, you can get both very high top speed and mileage.
Old Jan 7, 2019 | 12:51 PM
Richard A. Coyle
4wd Low
There is a aftermarket control for it.
https://www.usshift.com/?utm_source=...%20computer_MS
Should work well.
Rich
fredallard3
Jan 8, 2015 05:00 PM
filthy6
Jul 16, 2014 04:32 PM
hatemakings/n
Apr 22, 2008 07:15 AM
AdiDcn
Nov 6, 2003 12:14 PM
big block power
23
Mar 6, 2002 08:23 PM
