correct temp
Old Sep 28, 2003 | 02:44 PM
big6six's Avatar
big6six
correct temp
im wondering if i have anything to worry about 95 f150 53000 miles run and looks like showroom condition only thing is my temp gauge runs at 212 all the time around town nomatter how hot it is i guess thats good 210 i assume is good operating temp but when i get on the freeway even in 60 degree weather it runs close to 220 any reason for this and should i be alarmed. i have 265/75/15 tires on it with only 308 gears is this making the engine work to hard.
keith
Old Sep 28, 2003 | 03:38 PM
NM5K's Avatar
NM5K
Dunno...Might be running a tad warm. What stat do you have? Stock is 195 I think. You might have some clogging in your radiator. I'd probably do a good though flush and see if it helps any. Usually, when a radiator starts to become semi clogged, the first notice is overly warm temps on the highway. MK
Old Sep 28, 2003 | 04:11 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
You should flush and fill the cooling system if you haven't done so in a while. Also change the thermostat and thermostat gasket. Those two pieces are real cheap and good to change every now and then. Stock thermostat is 195 degrees. Also make sure that the radiator is clear of any junk that might be caught in the fins.
Old Sep 29, 2003 | 12:17 AM
bigbadjs's Avatar
bigbadjs
Nope. I've got 3.08 gears. No temperature problems here. I don't think those temps are a concern but you may want to have the radiator checked out. A higher capacity radiator will do wonders for cooling.
Old Sep 29, 2003 | 12:38 PM
borin&strokin's Avatar
borin&strokin
As long as it stays consistently at that temp, you have NO PROBLEMS. Almost every NEW vehicle runs that hot anyways.
Bigtruc
20
Dec 26, 2013 10:24 AM
Rushmore X
May 22, 2013 09:27 PM
Ford are best
May 6, 2013 08:16 AM
robdaniels
Nov 17, 2003 10:47 PM
dave thomas
Oct 1, 2001 11:07 AM
