Outfitting new 2019 f450 for pulling - Suggestions?
New to the forum and to communicating in this manner so bear with me please. Suggestions and experienced advice welcome as I take delivery this week of a '19 f450 King Ranch that will be used to pull primarily an Arctic Fox 29.5K (35ft) 5er, various small trailers and a 20' Goosed Flatbed. I don't expect to exceed 16kGVW (3k pin) on the 5er and less than that on the goosed flatbed. I am moving up from a '14 F350 SRW short bed (3.55ratio) outfitted for pulling with the B&W Companion and the B&W Turnover. I plan to get the new Companion base to fit the factory installed tow system for the 5th wheel and the Kurt gooseneck ball. Of the 70k total miles on the '14 F350, 50k was logged pulling the mountains west of the Rockies and it did a great job but the rear end just had to be rebuilt (all bearing sets, ring and pinion were ok) so decided this was the time to upgrade.
Any suggested "must haves" or other considerations about the F450 as I outfit this truck (other than preparing to pay at the pump a bit more) would be much appreciated.
I just assummed.... TPMS. Darn, Well, that's one thing I didnt check on as part of the King Ultimate and Towing whatever package. Seems like it had everything else that a design engineer could think of (and that I will never be able to figure out). Good suggestion. Maybe it has one. If not, Point well taken and will get it done, maybe to include the larger trailer too. Thanks.
That 450 will have no problems towing 16K pounds! Expect 9 mpg or so depending on speed and terrain and 14 to 16 mpg empty at highway speeds with the 4.30 gearing. They come with a 48 gallon tank so the loaded range should be close to 400 miles. Congrat's and can't wait to see some pics!!
If you like to drive long distance at one time you may be a little limited with even the 48 gal stock tank. I know that Titan has larger under belly or maybe an aux tank in the bed. I always hate getting to the 1/4 or below when I'm towing the 5th wheel and then hoping I can find a fuel stop that I can fit in before the wife has to grab a 5 gal jug and walk to the nearest pump and back. Just makes the rest the trip a little unpleasant.
Sounds like a great setup. Should tow stock just fine! Get the 5th wheel hitch adapted, and pull away!
One thing you'll want to do is re-aim the headlights once you get it loaded and hooked up. On my '17 450, it squats just enough with 3k+ lbs in the bed to warrant lowering the lights a little. My first trip loaded I had to stop at sundown because every single vehicle in the other direction was flashing me (not the good way). Truck should have a 3" hitch with adapters, so existing ball mounts should work. I'd drive it for a trip or two before you worry about a new fuel tank, as 48 gals goes a long way (relatively).
TPMS not even an option on the 450s, so an external setup with Schrader valve adapters is nice (with extra transmitters for trailer tires), though not absolutely required.
Did you order with the 360 camera system? If so, go to NavTV.com and get their COD-F50 or F51. Absolutely worth the money as you can display the cameras while driving (like a rear view camera behind the trailer.) (If you're in western Washington you could come see the cam on mine if you want).
Enjoy!
Enjoy!
Overall, a welcome upgrade to the 2014 F350SB for pulling stability and performance (other than tire issue which is significant) and no hesitation on recommending the F450.
Received 6,837 Likes
on
Thanks for the update . I have read where some of the 450’s are being shipped with a more off road looking tire from Continental. I’m not sure about the tire model but maybe they have shifted to a different tire. We are now looking at New Horizons Majestic 5th wheel, so it will definitely be a 450 when we pull the trigger on the trailer. Maybe I can find a good deal on a 19 or maybe just wait on the 20’s to come out.
