351 high water temperature
Old Sep 28, 2003 | 11:31 AM
jimbo81587's Avatar
jimbo81587
what would a high water temperature be for a 351 and what is a good running water temperature to shoot for.
My mechanical fan does not have a fan shroud. Do you think that i would need one? thanks for the help guys
Old Sep 28, 2003 | 03:58 PM
FoMoCo136's Avatar
FoMoCo136
195 if you have a 195 thermostat in it. If it is stock that would be good. If you want to race it the cooler the better.
Old Sep 28, 2003 | 04:07 PM
jwtaylor's Avatar
jwtaylor
If you want the fan to draw air through your radiator as best as it possibly can then you need a fan shroud. You could probably get away without one on a fairly stock motor you start modifications and the engine needs all cooling incentive it can get. As menitoned your water temp should be right around whatever your thermostat is, it may go past it initially a small bit on first warm up but after that it should stay close or below. Good luck
