Intermittent Miss With No Codes
Old 12-27-2018, 07:35 PM
Sevendog7's Avatar
Sevendog7
Sevendog7 is offline
Salutations all, I'm new to this community. I purchased my first Excursion two years ago after an exhaustive internet search for the right Ex. I finally found an 01 V10, 139k miles, in great shape at a dealership in Georgia. I needed something to tow my Jayco Travel Trailer (9k pounds) with the dogs, kids and gear, really so the dogs were in the cab instead of in a carrier in the bed of the F250. Vehicle ran great for about 10K and then I started having an intermittent miss. It was only one cyl but was very pronounced when towing, I thought the motor mounts were disintegrating from the vibe. Anyway, I took it to my trusty Ford Dealership and they replaced all 10 of my spark plugs, said the gaps were .08 in some cylinders. It ran good for about a month and started again. I took it back and they replaced the #8 Coil. Once again it ran good for about a month. This time I ordered 9 new coils and replaced them all. Once again I thought I had fixed it and towed the trailer to my fav fishing hole and on the way back, in the rain, it started missing again. I got under the hood and started touching things and as soon as I touched the #2 injector plastic plug it began missing. upon further examination I could see where the two wires were arcing. I replaced the connector and have had no issues. In retrospect I think that high humidity caused enough conduction path to cause the miss. I Just drove across the US and the Ex is a beast. I wanted to let some people know to check this out if you have the same type of issues.
Thanks
Old 12-27-2018, 09:51 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
A bit confused here, Are you saying you replaced the #2 injector pig tail ?
northwindone
Modular V10 (6.8l)
12-04-2016 05:51 PM
2000 roadking
2004 - 2008 F150
12-11-2009 06:48 PM
andrewzx92000
Modular V10 (6.8l)
10-13-2008 11:46 AM
ssjrsw
1999 to 2016 Super Duty
05-06-2007 07:11 PM
horsecop
1997 - 2003 F150
02-25-2004 11:06 PM
Quick Reply: Intermittent Miss With No Codes
