Sponsored by: Auxito
Need Help with Missing Engine
Old Dec 26, 2018 | 07:01 PM
4Paul4's Avatar
4Paul4
I have a 2002 F150 with a 4.2L 6cyl. I started running like crap, so I put new plugs, wires and coil on. No help. A compression test showed the number 2 cylinder was low. I pulled the heads and had a valve job done. I put it back together and it is missing. There is good spark coming out of the coil for cylinders 1/2/3. The spark for cylinders 4/5/6 is weak.I am not sure what to look at next.
Old Dec 28, 2018 | 08:33 PM
Bluegrass 7's Avatar
Bluegrass 7
4.2 ignition.
It is a waisted spark system not used on the v8 or v10 motors.
The cylinders are paired. Three coils for 6 cylinders.
Pairs are 1-5, 2-6, 3-4.
One plug get the positive side, it's mate gets the negative side for voltage. As you see the leading cylinder number on the passenger side is paired with a cylinder on the other side to keep mechanical balance during firing along with an internal balance to finish out the smoothing process.
Depending on how you tested spark, if by color it may mislead you but still be good.
Are you sure you have to correct fire order wired per cylinder to terminals on the coil pack. The coil terminals are numbered. #1 cylinder is front passenger side. Coil post numbering is 1,2,3 toward the back on it's passenger side. 4, 5, 6 on the other side.
Again there are three coils in the pack feeding 6 cylinders and need to be in the correct pairs.
Did you get any misfire codes?
Recheck your work.
Good luck.
Old Dec 28, 2018 | 09:37 PM
Sam I Am's Avatar
Sam I Am
4.2L V6 firing order. Very easy to get the plug wires wrong.
Old Dec 29, 2018 | 09:14 AM
formerjeepguy's Avatar
formerjeepguy
Are you not getting any codes? Is the CEL on?
I had a miss a couple months ago that turned out to be a failed injector, but it tripped codes indicating a lean bank and real time analysis showed a faulty injector. When I tested the electrical resistance of the injectors, the bad one showed an open circuit while the rest were something like 22 ohms.
Dond44
May 28, 2019 10:31 AM
canon7d
Modular V10 (6.8l)
Aug 10, 2018 03:12 PM
Collin Chappell
1997 - 2003 F150
Sep 7, 2017 01:46 PM
dsmitty643
Jun 23, 2017 06:11 AM
jessiewatterson
Escape & Escape Hybrid
Mar 26, 2007 09:16 AM
