P2290
Old Dec 20, 2018 | 09:36 PM
Campos02's Avatar
Campos02
P2290
2005 Ford F-250 with arp head studs,Egr delete, new oil cooler, new glow plugs, new pushrods. Just got updated STC fitting and updated high pressure oil stand pipe and dummy rail plug kit done a couple of months ago. It’s been going good until today out of no where. Got a P2290 “injector control pressure too low” Everything was fine all day until I had to go on a drive somewhere at about 4 this afternoon. I was running about 80 down a major high way for about 20 min everything is fine all my gauges were good until I started lacking power. About 20 min into the drive I would accelerate and my icp pressure would go down instead of up. As I started slowing down my truck stalled out and I had to pull over. Hasn’t started at all since. Changed my oil today and that didn’t help. Going to get my batteries tested tomorrow morning and if they are bad I’m gonna get new ones because my battery voltage was low on my sct livewire. Some help would be much appreciated
Old Dec 20, 2018 | 10:17 PM
vfelix702's Avatar
vfelix702
check for hi pressure oil leak but first unplug ICP on passenger valve cover and see if it starts
Old Dec 20, 2018 | 10:40 PM
Campos02's Avatar
Campos02
thanks man let me see what I can do
Old Dec 21, 2018 | 10:01 AM
Campos02's Avatar
Campos02
where should I check for high pressure oil leak? What does starting with out icp sensor do?
Old Dec 21, 2018 | 10:59 AM
navistarnut's Avatar
navistarnut
Search this forum for air test or google 6.0 air test for tons of info.
Starting it with the ICP unplugged won't hurt anything, it just forces the PCM to use default figures for the time being.
What it will do, if your truck starts, is tell you the sensor is likely bad and it's not a HPO leak internally.
Old Dec 28, 2018 | 09:26 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
As Navistarnut recommended, air test.
Do it from the IPR with the fitting for this test. You'll kill two birds with one stone, you'll check the screen on the IPR and if that's not it, pressure test and you should get your answer. However, if your IPR doesn't have a heat sheild on it, the IPR may be toast.
travelergypsy
Nov 12, 2018 11:03 AM
95 taco
Sep 25, 2017 03:57 PM
fomoconut
Nov 1, 2010 09:15 PM
FN74
Mar 14, 2010 11:09 PM
Bill_W
Nov 16, 2004 08:32 PM
