16.5 wheels bolt pattern the same ?
Old Dec 18, 2018 | 03:59 PM
jakeharp's Avatar
jakeharp
Question 16.5 wheels bolt pattern the same ?
Always looking around for 16.5's - 8 lug for the day I want to put a set on the ol'e truck. Came across a set for a 70's Dodge truck ? Where all these 70's 16.5's the same for bolt pattern for 8 lug ??
Old Dec 18, 2018 | 04:36 PM
butcher7788's Avatar
butcher7788
I got five nice original '77 Ford 8 lugs I'm wanting to get rid of taking up precious room in my garage
Old Dec 18, 2018 | 04:45 PM
butcher7788
Ok thats only 4.....the ugly spare is leaning up against a tree outside
Old Dec 18, 2018 | 04:58 PM
hickory1991's Avatar
hickory1991
Are they 16.5 or 16. Looking for some 16 inch steel rims for my 76 highboy.
Old Dec 18, 2018 | 05:00 PM
jakeharp's Avatar
jakeharp
And Red ! Where are ya located ? I will keep ya in mind, but shipping would be crazy.. Im traveling soon and should be able to pick some up along my way....
Old Dec 18, 2018 | 05:09 PM
butcher7788
16.5s. Just replaced them with 16s
Old Dec 18, 2018 | 05:11 PM
butcher7788
I'm in NE Pennsylvania. Got the covers too. Picture in gallery. Come n get em!
Old Dec 18, 2018 | 05:15 PM
hickory1991
Are those new 16's in the pic? Where did you get them.
Old Dec 18, 2018 | 05:24 PM
butcher7788
The red ones with tires are 16.5s and the covers were on them. The black one is a 16 inch that I blasted and painted but turns out it's too bent to hold a balance so garbage.
Old Dec 18, 2018 | 06:43 PM
fordguy2100's Avatar
fordguy2100
Don't know if you're traveling thru Indiana any time soon but I've got this set. The top is before I cleaned them, the bottom is after. What I didn't include is my angry face once I realized I cleaned them all up and they didn't fit on my dana44HD closed knuckle axle.
Old Dec 18, 2018 | 08:20 PM
440 sixpack's Avatar
440 sixpack
You can't buy 16.5 tires anymore.
Old Dec 18, 2018 | 08:27 PM
fordguy2100
Uh yes you can. You just can't run anything smaller than 35s and 37s end up being the best bang for your buck if you are wanting to go that big
Edit* ok you can run 33s but they are super swamper and I'm not a fan of that set
Old Dec 18, 2018 | 08:39 PM
440 sixpack
16.5 is considered an obsolete size. I should have said you can't buy any tires you'd want if you're over 21 years old.
oversized Gumbo mudders and junk off breed tires don't work for 99% of tire buyers but if you're in that 1% I stand corrected.
Old Dec 19, 2018 | 09:39 AM
jakeharp's Avatar
jakeharp
Im in Nevada so Indiana is a bit out of reach but those wheels are usually in demand, should be pretty easy to sell....
Old Dec 19, 2018 | 11:45 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
70's Dodge 16.5 rims should be lug centric and not hub centric, so you should be ok. SHOULD is like sort of close with a hand grenade.
65 choices of brand new 16.5...https://www.ntwonline.com/tires.html...m_diameter=373
Military takoffs or even NEW...Goodyear Wrangler MT II, BFG Baja TA and Goodyear MTR....
Goodyear Wrangler MT/R 37x12.50 R16.5
This tire is a Radial and has Dura Wall
Puncture Resistance Technology.
It comes in load range D and E. Max load
for D is 3,850lbs at 50 psi and E is
4,540lbs at 65 psi.
BIG FOOT TIRES
Tires. Off-Road. Tough. | CSM Army Tires - CSM Army Tires
https://www.easternsurplus.net/Parts.../HMMWV-Tires/1
And a opinion on the other side of the fence from a re-seller. https://www.rallequip.com/ (UPDATE 08/21/18)
Just saying.
