302 offset
Old Dec 17, 2018 | 03:07 PM
redraider25's Avatar
redraider25
302 offset
I am going to be putting a 302 and AOD in my '64 this winter. It currently has a 223 with a T98. My question is, how important is offsetting the motor 1.5" to the passenger side? The reason I ask is because most of the aftermarket swap motor mounts are designed to the center the motor. The 223 that is currently in the truck is centered. Also, the truck currently has a 2 piece drive shaft and I am planning on going to a 1 piece. Any issues that I need to look out for other than pinion and crank angle?
Thanks in advance.
Old Dec 17, 2018 | 09:07 PM
redraider25
Is this a non issue? Anyone?
Thanks
Old Dec 17, 2018 | 09:36 PM
James_Western_Canada's Avatar
Well, the engines are generally offset to the passenger side to allow some room for steering gear on the drivers side......so take that into consideration
And a one piece driveshaft shouldn't be an issue on a SWB truck
Schmitty
Jun 28, 2025 02:22 PM
EDMist
May 31, 2008 03:59 PM
right66
Sep 19, 2004 10:26 AM
JByrd1173
Sep 16, 2004 08:55 PM
jcs1966
May 20, 2002 02:44 AM
