1964 Ford F100
next is to figure out how to tune this thing. Any ideas/guidance/tips?
it's got an edelbrock 1406 carb on it. Idle is sitting around 1000, and when i drop it into reverse or drive it drops to around 700-800. Only issue is if i cruise on the freeway and exit if i dont drop it into neutral at the stop itll stall out.
Originally trucks with automatics would have had the anti-stall dashpot attached to the side of the carburetor. If you don't have one installed that can cause a vehicle to stall in those conditions. This one likely won't be correct for your current carburetor, but it's what they installed on the 2100. Different carburetors used different methods.
Chad
Chad
jjtxaz24,
I have those same heads on my 1970 429 out of a Torino GT. Good heads for cast iron heads. I have a 1964 F100 with the same motor and a C6 trans as well. What exhaust are you running on it? Headers, I'm hoping? I'm looking for a set of long tube headers that will fit that combo. What front suspension do you have in your truck?
Doug
Doug
Doosenberry
18
08-03-2019 07:17 PM
oldracerjones
03-19-2019 05:47 PM
RCS1951F5
Ford Truck Parts for Sale
02-03-2018 02:11 PM
ghostwhite
05-04-2011 10:43 AM
65fordguy
16
10-23-2010 08:08 AM
