Front Differential
Old Dec 15, 2018 | 06:48 AM
Warhound's Avatar
Warhound
I had an Eaton E-locker installed when I did a factory 4:30 gear swap so now im running front and rear E-lockers
Old Dec 15, 2018 | 09:05 AM
BillyE's Avatar
BillyE
Do you find much improvement in traction with the front locker engaged? How is steering?
Old Dec 15, 2018 | 11:05 AM
skanj0's Avatar
skanj0
I know you directed your question to another poster, but I thought I would share my experiences as well.
I put an Elocker in the front axle of my 06 Super Duty. It worked great though I didnt get the opportunity to use it very much. I regeared so it seemed like a sin to just put an open carrier back in the front axle.
An elocker in the front of a Super Duty is a great option. There is a lot of weight over the front axle - especially with a diesel. I didn't find it hard to turn - even in full circles - if the ground was a bit soft or a little muddy. Frankly I found myself using it most when up in the Sierras with the lance camper loaded on the back. When I approached a rough or rocky section of trail, or a water crossing, I would engage it. Once I got through that spot I would disengage it.
I plan to also put one in the front axle of my 2016 Super Duty.
Old Dec 15, 2018 | 08:06 PM
17 Oaks's Avatar
17 Oaks
Give this company a call, NO ONE knows more about Ford D 60's than they do. I ran their ProRock 60's w/ARB's and 4:88 gears.
If you are looking for bulletproof they make it, ball joints, axles all kinds of stuff.
They are goof folks and know their stuff, give them call, they well help.
Old Dec 17, 2018 | 06:08 AM
dnewton3's Avatar
dnewton3
And "this company" would be .... ???
For goodness sake man, if you're going to tempt us, at least don't leave us hanging!
Old Dec 17, 2018 | 09:04 AM
17 Oaks's Avatar
17 Oaks
Sorry all was getting ready for early Christmas yesterday due to travel outside the US. Took half the morning just to write a couple of posts as I kept getting called away from the computer.
They do a lot of speciality work for Ford, when Ford gets a request for something not in their offering, usually DoD or oil companies doing exploration work. They use Ford D 60's for all there aftermarket axle builds.
https://www.dynatrac.com
Old Dec 26, 2018 | 02:59 PM
bigred460ci's Avatar
bigred460ci
I’d wait for the aftermarket to catch up. No way I’d bother swapping front and rear ring and pinions to go from 3.55 to 3.73. It’s just not worth it.
Doesn't look like aftermarket will have 4.10's available any time soon, so I'm going to go ahead and have the Eaton Truetrac #915A387 installed in the front of my '18 F350 and wait on the gear change. I contacted Eaton one more time and suggested that they take a second look at the new Super Duties but they unfortunately gave me the same response:
Eaton Performance (Eaton Performance Support) Dec 14, 17:37 AST Hello Mark,
Thank you for your interest in this differential application. We currently do not have a part available to fit that specific application at this time.
Thanks,
-Eaton Performance Support
Old Dec 27, 2018 | 06:49 AM
skanj0's Avatar
skanj0
Thanks,
Just to be clear, your last post is largely referencing the Dana M275 rear axle, correct? Lots of diff options and Dana gearsets exist for the front Dana 60 - including a 4.10 ratio.
Old Dec 27, 2018 | 06:54 AM
bigred460ci
Correct, I'm referring to the rear M275 when I referred to a 4.10 ratio.
Old Dec 27, 2018 | 06:57 AM
willynilly's Avatar
willynilly
you could be waiting a very long time for 275 gear sets. if its a specialty axle thats only used in f250 and 350 then it may be a long time
Old Dec 27, 2018 | 07:02 AM
bigred460ci
Agree. The Truetrac is a higher priority for my anyways.
matt.castaneda
Jul 8, 2015 10:27 PM
5.4L to Freedom
Nov 20, 2009 12:46 AM
Thunderjet4x4
Oct 2, 2008 12:37 AM
mjolnir
Modular V10 (6.8l)
Nov 25, 2006 10:43 PM
BigBully
Sep 13, 2006 01:04 AM
