88 Ford AOD problem
Old Jul 16, 2001 | 03:37 PM
mrrich's Avatar
mrrich
88 Ford AOD problem
I need some Ford AOD expertise, I have and 88 Big Bronco with and OAD behind a 302. The problem is that it won't go into reverse, neutral or OD but it goes in drive fine and shift just fine. No there's no evidence of burnt fluid or any other problem. I took it to one dealer and he said the Sun gear was bad, well I tore the trans all apart expecting to find a bad sun gear but the mechanic was obviously an idiot since if the sun gears was bad the trans wouldn't have worked all and there would have been metal bits all through the trans. So my question is has anyone had this problem before, is there some adjustment that can be made? Oh yes I put it back together and basically rebuilt it with all new seals and gaskets in the trans and it still goes forward just fine but no rev, neut or OD.
Rich
Old Jul 16, 2001 | 10:56 PM
Fordtruxrok's Avatar
Fordtruxrok
88 Ford AOD problem
I have an 86 150 with a 302 and a C6, which recently started doing something similar. In drive it goes through the gears, and in 2 it's in second gear. In anyother gear its in first, in reverse it's in first and reverse at the same time. Anyway, I called a trans shop and he said the manual valve in the valvebody could be stuck.
Hope this helps!!!
John
Old Jul 17, 2001 | 06:23 AM
mikes66's Avatar
mikes66
88 Ford AOD problem
