Sponsored by: Real Truck
Need new batteries
Old Dec 7, 2018 | 04:26 PM
Greenlawnracing's Avatar
Greenlawnracing
Need new batteries
Any recommendations? Normal use truck, more of a grocery getter than anything else these days and is a second vehicle that gets used about once a week for short trips.
I did see that most of the big three auto parts stores have 20% off with some limitations.
Old Dec 7, 2018 | 08:54 PM
Djosbun's Avatar
Djosbun
Doesn’t Johnson Controls manufacturer a high percentage of store-branded batteries? My advice is to NOT buy an Optima battery. It is WAY overpriced and just marketing hype.
If you can swing the extra $$ for one, get an AGM battery. ‘Advanced Glass Mat’ batteries have their internals engineered differently than your typical lead acid batteries. They are able to handle increased vibration, plus other benefits. AutoZone sells them and I’m sure others do as well.
— Dave
Old Dec 8, 2018 | 12:42 AM
Colorado350's Avatar
Colorado350
Northstar AGM, not cheap but you get what you pay for...
NORTHSTAR Pure Lead Automotive Group 65 Battery NSB-AGM65
Amazon Amazon
Old Dec 8, 2018 | 01:01 AM
marksman76's Avatar
marksman76
I always buy the Motorcraft OEM batteries
Old Dec 8, 2018 | 06:00 AM
CollinsCD's Avatar
CollinsCD
I have also had great luck with Motorcraft batteries. I know it's made by someone else and just labeled but better than the cheaper batteries.
Old Dec 8, 2018 | 07:31 AM
Chuck's First Ford's Avatar
Chuck's First Ford
my OEM Ford battery lasted 8/11 to 9/16... and 149,000 miles.
Old Dec 8, 2018 | 08:26 AM
egolsen-F250's Avatar
egolsen-F250
There are only a few battery makers in the country who make all the batteries. I used to work for NAPA corporate and we handled Excide, who makes a lot of different brands. We switched to East Penn Manufacturing who make Deca as well. The company wide rate of defects fell from 8% to 1%. That is a lot. Johnson Controls also makes a very good battery. They make Interstate and several other brands. Prior to NAPA switching I bought interstate even though I could buy NAPA at 10% over cost. Just wasn't worth the failure rates to save the money. If you are going lead acid avoid Exide. You should google each brand, but I believe Walmart and Advanced are Excide, Autozone is Johnson Controls.
Old Dec 8, 2018 | 11:57 AM
Djosbun's Avatar
Djosbun
This is awesome info! I appreciate the post and sharing your knowledge.
— Dave
Old Dec 8, 2018 | 12:43 PM
Greenlawnracing
So taking a quick look at Autozone, Advance and Oreilly - all of them offer an AGM, but it is 750 CCA vs 850 that the others offer.
Doesn't the truck need 850?
Old Dec 8, 2018 | 01:10 PM
big315's Avatar
big315
I would make sure you replace both at the same time.
Old Dec 8, 2018 | 02:15 PM
quietman's Avatar
quietman
If you are a Costco member, get them there. They are Interstate and have a good warranty policy.
Old Dec 8, 2018 | 02:54 PM
jws24's Avatar
jws24
I also have had good luck with the Motorcraft batteries Ford installs.
Old Dec 8, 2018 | 05:10 PM
danno676's Avatar
danno676
I just put two Napa 7565 850 CCA batteries in my truck. Napa or interstate batteries would be the only brand I used, leaning more towards the Napa's.
Old Dec 10, 2018 | 07:09 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Besides Deca (which I've heard good things about) is there a way to tell what other batteries East Penn Manufacturing markets?
Old Dec 11, 2018 | 06:09 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Actually I think it's Deka - Deka Batteries.
