Hey new to this site,
I have an 71 f100, Im looking for a piece of the exterior under the grille that sits underneath the directionals behind the front bumper. Its my daily driver 80 miles a day..been driving like this for 2 years . Figured its time to get it fixed, installed. It seems like this is not a common part to seek out, as I cant seem to find it. Not sure exactly what you would call it, which might help as well. I appreciate any help
Are you talking about the lower valance / rock shield? This is the piece that the turn signal assemblies mount to. Where are your turn signal assemblies mounted now? Or do you have an earlier grille mounted? A 67-68 and a 69 grille will mount to the 70-71 and 72 trucks with no problem. If your using the 67-69 grille, then you need that valance. If your using a 70-72 grille then you need to find that valance.
