Outer Tie Rods...
Old Dec 4, 2018 | 08:41 AM
L-ight's Avatar
L-ight
Outer Tie Rods...
So I have some play in my steering 1"-2". Truck has 97k miles. Would it be ideal to replace just the outer tie rods first before tackling the inner tie rods then possibly the steering box? Do inner tie rods wear just as fast as outer tie rods? Truck is a 2wd.
Old Dec 4, 2018 | 08:50 AM
Walleye Hunter's Avatar
Walleye Hunter
Have you checked them for condition? I wouldn't just throw parts at it hoping it cured a problem.
Old Dec 4, 2018 | 08:53 AM
L-ight's Avatar
L-ight
I will this evening. I will use the pliers method by squeezing the tie rod. If it has play in it then it is bad. Saw this when doing research. Do you agree?
Just called into the Ford dealership where the truck was serviced all its life and back at 65k miles the inner tie rods and ball joints were replaced. Nothing stating the outer tie rods.
Old Dec 4, 2018 | 09:26 AM
Walleye Hunter
I don't know how you check a tie rod end and I would only be guessing.
Old Dec 4, 2018 | 09:30 AM
L-ight's Avatar
L-ight
just recently saw it on Youtube that if you see any movement when squeezing the rod end that it is bad. But at nearly 100k miles, play in steering wheel, Moog tie rods at ($45 out the door) is cheaper than taking a risk at damaging my steering box. Still not a bad idea to change them even if they are good. Though 100k miles on a heavy duty truck the odds are they are close to being bad if not bad already. Play in steering wheel is one side effect of bad tie rods.
Here is the video I saw
Old Dec 4, 2018 | 09:58 AM
Walleye Hunter
OK, I didn't know of that method, my guess would have been to have someone gently rock the steering wheel while looking for play in tie rod end. RFX is a go to for some on here (including me) and Michigan bearing is a good to deal with supplier. Right now I'm having trouble with their website but here it is.
MI Bearings
Old Dec 4, 2018 | 10:23 AM
L-ight's Avatar
L-ight
MI Bearings
I went ahead and ordered the Moogs outer tie rods.
Old Dec 7, 2018 | 11:49 PM
'88 E-350's Avatar
'88 E-350
Squeezing them will show minor wear that may not be evident when looking at them while someone rocks the steering wheel. When doing the steering wheel rock to check tie rod ends putting a hand on them will often reveal more than the eye can see.
Old Dec 13, 2018 | 10:58 AM
BillyBob69's Avatar
BillyBob69
If you do the WATCH WHILE SOMEONE MOVES THE WHEEL.. Just make sure you have someone you trust at the wheel.
Old Dec 13, 2018 | 12:20 PM
Walleye Hunter
Especially if they say, "OK, hold my beer".
Old Dec 13, 2018 | 12:23 PM
BillyBob69's Avatar
BillyBob69
Now that is a challenge. hehe
Huskersteel
Aug 4, 2011 02:20 PM
turnkyle
Apr 14, 2011 09:40 AM
7.3 Ex
Jun 10, 2008 12:11 AM
Gr8ride
Sep 3, 2003 01:27 AM
