'85 Engine Help Needed--Long
I need your advice on the resurrection of my truck:
85 F150 300-6 4 speed 150,000 miles, purchased new by my folks.
Blown headgasket two months ago--slight smoking, slight bubbling of coolant/oil out driver's side of block (at head gasket)...
Was completely stock (1 bbl carb in poor condition--stuck choke, ran ok and passed emissions but in sad shape), possibly warped exhaust manifold (it was a bitch to get back onto the front dowel pin a year ago when I replaced the I/E gasket). Air pump and all the emissions stuff is in there, but doubtful that much of it was working (Several unidentified wires were burnt through).
Offy Dual-Plane ready to go on, but I know very little about it (like even whether or not to install it with a stock exhaust--at first glance it looks like it'd work that way).
Head is off, pistons/cylinders look good, pushrods in good condition with slight carbon.
Primary goal is to get it running at minimal cost, but I want to balance that with a few more ponies and doing the right amount of work while I'm in there.
Any help or thoughts are greatly appreciated.
