1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Aluminum SD not for me, yet!
  #31
Old 12-07-2018, 01:14 PM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
Its Comin Right for us!
Received 1,459 Likes on 951 Posts
bodywork on aluminum is more expensive. As it becomes more common the cost will come down.
  #32
Old 12-07-2018, 01:28 PM
82_F100_300Six's Avatar
82_F100_300Six
82_F100_300Six is offline
some of the 17+ issues i am reading about in their section
-uncooperative tailgate handle mechanism
-long crank before starting (gas)
-fuel filling ( pump shutting off)
-no start (gas)
-cold start squeal (gas)
-frozen door latches
-death wobble
-transfer case leaks
-drive shaft clunk
-4x4 not engaging
-hubs falling apart
  #33
Old 12-07-2018, 01:33 PM
T diesel's Avatar
T diesel
T diesel is offline
Don't forget the "water in electrical connectors" issue.
  #34
Old 12-07-2018, 02:07 PM
82_F100_300Six
-cab clearance lights leaking, installation not flush
-moonroof leaking
-moonroof stuck open
-moonroof stuck shut
-moonroof stuck halfway open, off track
  #35
Old 12-07-2018, 02:26 PM
Batman7777's Avatar
Batman7777
Batman7777 is offline
Geez... Glad I bought 2016
Almost been three years (36k miles). Not once in the shop for repairs.....
  #36
Old 12-07-2018, 02:28 PM
82_F100_300Six
oh yeah i forgot about the holes for the towchain hooks that do not accept the hooks from tow chains.
and there is a major cluster about hitch sleeve inserts and sizes, 3 " receivers.....
  #37
Old 12-07-2018, 04:52 PM
Deuce40s's Avatar
Deuce40s
Deuce40s is offline
-no start (gas)
-death wobble
-drive shaft clunk
-4x4 not engaging
-hubs falling apart
-moonroof leaking
The sad thing is, all of these issues were present in the 2015 F-150s and they were never addressed. I started researching my truck in early 2015 when the new F-150s came out. I decided to get a 2016 SD instead of 2017 because of all the issues they were having that weren't getting addressed.
Our 2016 and older SDs have problems, but not on the scale of the later models.
I have a 2015 and 2017 F-150 at work I drive all the time, most of these issues I've experienced first hand. The door latches freezing is absolutely unacceptable.
  #38
Old 12-07-2018, 07:08 PM
jav_eee's Avatar
jav_eee
jav_eee is offline
Isn't there a recall for that?
  #39
Old 12-08-2018, 06:57 AM
T diesel's Avatar
T diesel
T diesel is offline
Originally Posted by Just Strokin
The aluminumm SD hi on its 3rd production year, so you would not bee a beta tester....also, the F150 is on it 5th year I think.....so.,,again, not a beta tester...GM is going to some carbon fiber, aluminum parts also in 2020...
Still in BETA....
https://www.ford-trucks.com/forums/1...l#post18349215
  #40
Old 12-08-2018, 07:16 AM
FractureCritical's Avatar
FractureCritical
FractureCritical is offline
Leaf.
Springs.
100 years of R&D behind a simply more durable, reliable, (and simple) front suspension arrangement.
Hanging almost 1000 lbs of pig iron front axle and commercial grade wheels/tires from a pair of coils was never a good idea. Been a problem even on Jeeps since the XJ came out more than 30 years ago.
I will I’ll argue that the marginal ride improvement is just not worth it. My CJ with OME leafs and Rancho 9000 shocks rode as well as my IFS Tacoma, and I drove them interchangeably for years.
  #41
Old 12-08-2018, 08:00 AM
don123's Avatar
don123
don123 is offline
Problems with my 15 f350 with 43k and 4 winters plowing. None..no rust no death wobble. Just a little whine from the motor when she’s cold. I use a gallon of fluid film a year on the undercarriage. I would like to upgrade to a new truck but I haven’t completely warmed up to the new body style. I do think aluminum is a good idea..lighter and should last longer than the steel body for most.
  #42
Old 12-08-2018, 08:10 AM
FractureCritical
In 20 years of designing and building road and rail infrastructure, I can confidently say it’s all in the coatings, not the materials. I will also take galvanized steel over painted aluminum any day of the week. Given that the engineers at ford refuse to galvanize, we’re left with painted steel or painted aluminum from them, in which case I will grudgingly accept the painted aluminum for its marginally better corrosion protection.
  #43
Old 12-08-2018, 08:28 AM
don123's Avatar
don123
don123 is offline
I will say when I first looked under my brand new truck there was lots of surface rust on it. Someone who’s not as **** as I am about stopping the spread of rust might experience a lot of rust in a few years. Ford needs to do a better job. I complained about it and the salesman told me “There all like that” and he was right about that!
  #44
Old 12-08-2018, 01:17 PM
82_F100_300Six
to be fair i could probably go back to 2011 and forward and find two million threads with people complaining about their 2011-2016
  #45
Old 12-09-2018, 04:57 AM
KubotaOrange76
Originally Posted by FractureCritical
Leaf.
Springs.
leave it to ford to figure out how to screw that up. 85-97 f-350 front shackle design shared with the ttb setup 😂
Quick Reply: Aluminum SD not for me, yet!
