Oil Leak
Old Sep 27, 2003 | 11:13 AM
lumprsmith's Avatar
lumprsmith
Oil Leak
Hello To FTE I Have a 1994 F-150 4X4 5.0 /302
with 95,000 miles.
I seem to have an oil leak problem thats coming from the drivers side rear of the motor.
Ive gone from adding 1qt of oil a month to 1qt a week
What should I be looking for?
Oil pan gasket, rear main seal or sending unit.
Any help or suggestions with this problem would be appreciated.
Thank you
Old Sep 29, 2003 | 02:10 AM
c96drumm's Avatar
c96drumm
Might be running down from the valve cover.
Old Sep 29, 2003 | 07:22 AM
fishin1976's Avatar
fishin1976
I would check the oil pan gasket. If you would have said rear center, I would have said rear main seal. I would also ckeck your valve cover gaskets, that could be it also.
