Hitch Sleeves are a Joke, Ford
I had read so many complaints about this issue that before my truck arrived I had this $35 ($30.98 right now) solution sitting in my garage:
At the same time you can add a hitch pin to your order for $4.26:
The reducers have tabs that keep the holes aligned. They fit great and are foolproof to use. I towed my 9000 pound trailer 50 miles last week using my Equal-i-zer hitch with a 2" shank.
Because my truck was a special order and never sat on the lot, I got the 3"- 2 1/2" reducer and a hitch pin but I can see how trucks just sitting on the lot might have their sleeves and pins swiped. It would take about 1 second. I keep mine locked up in the truck when not in use.
~S
There are tabs on both the 2 1/2' and 2" sleeves so that when they are both fully pushed in, the holes on the hitch and both sleeves align. A little wiggle of the pin and it slips right through.
I can't imagine the weight of an Equal-i-zer hitch head with a 3" shank. For the minimal price of these sleeves, I much prefer to keep using my current setup. I also have a few different drop and adjustable hitches with 2" shanks. As I upgrade hitches, I will probably go with 3" shanks for convenience but for now, I see no reason to ditch the equipment I already own.
That's really funny.
Because I'm a fat ******* and my four boys like to bike, then I do to.
We haul the bike rack on the back of the fifth wheel, then transfer it to the 450. So we're often monkeying with sleeves in the dark.
I'm just bitching, really.
Received 6,834 Likes
on
#29
on
From the Owner's Manual:
Did you even get the hitch pin? If not, I say you got screwed.
Hitch components (If Equipped)
The following components are required. Some are provided in certain vehicles.
• A trailer hitch with a 3 inch receiver and 5/8 inch hitch pin rated to tow up to 21,000 lb (9,525 kg).
• A hitch pin sleeve stored in the glove box to be used when mounting the 3 inch drawbar.
• A clevis pin to help keep the hitch pin in place.
